1841 Alignment Error
ckuriyar74
I have Cisco 1841 router and see alignment error. The old IOS was c1841-advsecurityk9-mz.124-11.T2.bin and as per cisco suggestion upgraded to c1841-advsecurityk9-mz.124-15.T1.bin
Still i see alignment error. As Cisco suggestion the alignment errors are due to misaligned reads and writes caused by a software failure and suggests to upgrade to latest IOS.
I have configured IPSec tunnels and not used AIM VPN module.
Router#sh alignment
Alignment data for:
1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(15)T1, RELEASE SOFTWARE (fc2)
Compiled Wed 18-Jul-07 04:47 by prod_rel_team
Total Corrections 3, Recorded 2, Reads 3, Writes 0
Initial Initial
Address Count Access Type Traceback
EE95B1CE 1 32bit read 0x6029AAF4 0x6029DC60 0x600297AC 0x621D37B8
0x621DAE7C 0x621D728C 0x621D7558 0x6004A188
EE8F99CE 2 32bit read 0x6029AAF4 0x6029D650 0x600297AC 0x621D37B8
No spurious memory references have been recorded.
Any one has suggestion to this problem?
5 Replies 5
guruprasadr
Level 7
Level 7
HI,[ PLS RATE IF HELPS ]
The failure was caused by a software defect.
Refer Cisco Bug Reports for FIX: The IOS "C1841-ADVSECURITYK9-M" has Several Bugs and listed below the BUG ID's for the same. Use the correct IOS in which the BUG has been FIXED in. Pls see below for Details:
BUGID:CSCsd69052
Fixed in:12.4(9.15) 12.2(18)SXF6 12.2(18.5.11)SXF 12.2(32.8.11)SX2 12.4(9.15)T
Title:Netbios/NAT optimization
BUGID:CSCse70141
Fixed in:12.4(12.4) 12.4(12.1)T 12.4(12.2)PI6
Title:Tracebacks @ ipnat_nbss_is_special_packet
BUGID:CSCsh02342
Fixed in:12.4(16.6) 12.4(13.9)PI6a 12.4(16.6)T
Title:NAT cannot create new inside entry
BUGID:CSCsi93916
Title:Alignment Error/ Traceback @ ipnat_nbss_is_special_packet/ latest SPUD
PLS RATE IF HELPS
Best Regards,
Guru Prasad R
GuruPrasad,
I tried to serach the right IOS in which the alignment error is fixed. When i see the bug toolkit Cisco says Right now there is no workaround.
Can you suggest me the right IOS.
HI,
You don't have to Search for an IOS specifically which has alignment error is fixed.
See my Previous Post in the "Fixed in" line where i have listed the IOS Version in which the BUG has been fixed.
DO RATE ALL HELPFUL Posts
Best Regards,
Guru Prasad R
Andyfweih
Dear business partners & valued customers :
I am pleased to enclose it for your reference.
We can give you better price depending on the items and Qty.
Large quantity new & used Cisco and networking products that aren't
included in this catalogue. Feel free to contact us with your
requirements.
50% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-24TS-S
WS-C3560-48TS-S
WS-C3560G-24TS-S
WS-C3560G-48TS-S
WS-C3750-24TS-S
WS-C3750-48TS-S
WS-C3750G-12S-S
WS-C3750G-24TS-S
WS-C3750G-24PS-S
60% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-48TS-E
WS-C3560-24TS-E
WS-C3750G-24T-E
WS-C3750G-24TS-E
WS-C3750G-24PS-E
WS-C3750G-48TS-E
WS-C3750G-48PS-E
Looking forward to receiving your enquiries soon.
Best Regards
Andy Feng
FEDON(INT'L)DEVELOPMENT LTD
MSN:fweih688@hotmail.com
Email:fweih688@yahoo.com.cn
Http://fweih.diytrade.com
Guruprasad,
Below is the Cisco Bugtoolkit output.
Symptom:
A Cisco router can experience Alignment Errors related to NAT. This Alignment Errors are related to NBSS.
Workaround
As cisco says the status is still open.
