2811 EoMPLS
vedrank72
Frequent Visitor
Frequent Visitor
has anybody configured or seen EoMPLS on Cisco 2811 routers?
I have 2811 with IOS C2800NM-SPSERVICESK9-M Ver 12.4(17b), configured as PE router,
but It only permits me l2tpv3 encapsulation:
interface FastEthernet0/1.3000
encapsulation dot1Q 3000
router(config-subif)#xconnect 10.10.10.10 3000 encapsulation ?
  l2tpv3  Use L2TPv3 encapsulation
Is it due to a IOS version or EoMPLS can't be configured on 2811 Series?
A.
Robert Taylor
EoMPLS is supported on 2800 series ISRs.
Support starts at 12.4(11)T code, so you will need to upgrade to get these features on the 2800.
Robert Taylor
vedrank72
Frequent Visitor
Frequent Visitor
Thank you very much
vedrank72
Frequent Visitor
Frequent Visitor
I can't open niether link, did you post
correct ones?
regards,
Vedran
Sorry ... my mistake, those were internal.  Normally I check that sort of thing.
I dont see a similar document posted externally.  However, the details are the same (need 12.4(11)T or later, and SP services or Enterprise services feature set or better).
