3550 reg
ramnetindia
Dearsir,
thanks for ur reply i gone through flash_init
iam having 16mb flash but its showing not enough space
Initializing Flash...
flashfs[0]: 4 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 16128000
flashfs[0]: Bytes used: 5571072
flashfs[0]: Bytes available: 10556928
flashfs[0]: flashfs fsck took 9 seconds.
...done Initializing Flash.
plz help me what can i do next
In this which ios is suitable
swich3550 12t
srinivas.D
ahmednaas
Level 4
Level 4
in you original post you had this:
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
Timeout while verifying the CPU Interface channel 0 on switch core 1
POST: CPU Interface Tests : End, Status Failed
This most likely indicates a hardware failure.
