3750G - core router switching, best practice?
netguyz08
As a best practice recommended by another network engineer to remove the load on our firewall, I took the routes out and put them in our Cisco 3750G which works a core switch for 10 different locations. Here's the routing I put into the switch:
ip default-gateway 192.168.100.1
ip classless
ip route 192.168.101.0 255.255.255.0 192.168.100.1 20
ip route 192.168.102.0 255.255.255.0 192.168.100.10 20
ip route 192.168.103.0 255.255.255.0 192.168.100.10 20
ip route 192.168.104.0 255.255.255.0 192.168.100.10 20
ip route 192.168.105.0 255.255.255.0 192.168.100.10 20
ip route 192.168.106.0 255.255.255.0 192.168.100.10 20
ip route 192.168.107.0 255.255.255.0 192.168.100.10 20
ip route 192.168.108.0 255.255.255.0 192.168.100.10 20
ip route 192.168.109.0 255.255.255.0 192.168.100.1 20
Just double-checking if this is a best practice, and is helpful? Or if there are other configuration issues I should look into, too? Any other settings I should ensure are in the switch so it all works?
milan.kulik
Level 10
Level 10
IMHO, you should use
ip route 0.0.0.0 0.0.0.0  192.168.100.1
instead of
See http://www.cisco.com/application/pdf/paws/16448/default.pdf
for details.
HTH,
Milan
6 Replies 6
milan.kulik
Level 10
Level 10
instead of
for details.
HTH,
Milan
Jon Marshall
ip classless
Milan is correct, you need to change the ip default-gateway to ip route 0.0.0.0 0.0.0.0 statement.
However it's not really possible to say whether you need to do anythiing else as we have no idea of your topology. The 3750 is acting as core switch, does that mean you are doing inter-vlan routing on the switch ? If so why did you have a default-gateway in the config ??
The routes you have moved from the firewall, does the firewall still need to know about these routes and if it doesn't why not. Simply moving routes from one device to another doesn't mean it will all necessarily work. For example if you were routing your vlans off the firewall and that is why the routes were on the firewall then you can't just move them to the 3750 without moving all the vlan routing to the 3750.
So perhaps if you could clarify -
1) what are these routes for
2) why did the firewall have them in the first place
3) what is the the 3750 actually doing when you say it is a core switch
Jon
Jon,
I implemented the ip route that Milan suggested and took out the default-gateway. Did not restart or see an immediate change in traffic (actually looking into some traffic slowness on the network currently). So to answer your questions:
1) The routes are in the switch because there is an MPLS network and a cable connection as the main internet connection. MPLS was the main internet connection, but ties in 10 other offices. The routes send some of the LANs to the firewall because there are IPSec tunnels now with a couple of offices also on cable instead of MPLS. And the other routes are the other offices still on MPLS and go back out the MPLS router.
2) The firewall with all of the routes in them to begin with, was done by the previous IT person. That person apparently was told that it needed to be done at the firewall (which had the cable connection on it) and redirect the internal IPs for the MPLS network back to the appropriate place. These exact same routes are simply moved so the firewall will be unburden by handling routes.
3) The 3750 switch then sits in the middle of the main corporate office, and now routes traffic as described above. It also handles the Cisco IP phones for the main office, and then that is it from what I have seen in the config.
netguyz08 wrote:
Jon,
Okay, that makes sense then. So does the 3750 actually need a default-route and if so it should probably be the firewall i'm assuming because that would be where internet traffic was sent to ?
Jon
Jon,
Yes, the default route is sending data over to the firewall to use the cable connection. The firewall has a one route added besides the defaults (it is Sonicwall) which takes the LAN IPs (192.168.0.0/255.255.0.0) and sends them to the switch, with a metric of 100.
Then you should be fine.
Jon
