3750X output queue drops
Daniel Hunter
Community Member
I have a 3750X-24T in our production environment that is showing very high number of OQD's in the 'show int sum' output for 4 of the Gigabit interfaces; the interfaces are each in a seperate port channel and there are no OQD's for the relevant port channel and there are no output drops showing in the output for the 'sh int' command for each interface.
The following are the OQD's for the relenvant interfaces
Gi1/1/1:     0
Gi1/1/2:     0
Gi1/1/3:     0
Gi1/1/4:     0
Gi2/1/1:     4252879251
Gi2/1/2:     4251090833
Gi2/1/3:     4251754140
Gi2/1/4:     4294942102
Po1:          0
Po2:          0
Po3:          0
P04:          0
Gi1/1/1 and Gi2/1/2 assigned to Po1, and so on.
IOS version:     C3750E-IPBASEK9-M 12.2(58)SE2
I am assuming this is a bug but would be interested to hear if anyone esle has experienced this problem or knows of a fix.
Prasan Venky
Level 7
Level 7
Its seems very huge packet drops and check whether it increases by clearing and setting the interval time to 30 secs.
paste output of sh interf switching.
If it shows any incorrect value in the output may be you are hitting this bug CSCso81660 found in the known affected versions.
http://tools.cisco.com/Support/BugToolKit/search/knownAffectedVersions.do?method=fetchKnownAffectedVersions&bugId=CSCso81660
Rate if it helps....
Prasan Venky
Level 7
Level 7
Daniel Hunter
Community Member
Sorry for the slow response, I thought I'd already actioned this.
Software bug is correct answer.
