4311 menu command
Adrian O'Neill
Community Member
Hi there,
      I was hoping somebody may be able to help. My work currently use 2901 routers, and within these use the 'MENU' command in order to run files into the CLI to select which ports we need to use.
We have just migrated to 4311 routers and the menu command doesn't appear to be in the CLI.
Does anyone know if this is an option that is no longer available, or if there is an alternative?
Kindest Regards
Adie
Mark Malone
Hi do you mean 4321 there is no 4311 in 4000 series ?
anyway its there on 4331s as below off one of my routers  , whats your image/license
xxxxx#sh ver | i isr
System image file is "bootflash:/isr4300-universalk9.03.16.03.S.155-3.S3-ext.SPA.bin"
xxxxx#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
xxxxx(config)#menu ?
  WORD  Name of this menu
Have you enable Appx license in order "menu command" work ?
Adam S.
Visitor
The Menu commands require the appxk9 license.
You can try the commands below:
In order to enable this license you need to follow the next steps:
#conf t
(config)#license boot level appxk9
% use 'write' command to make license boot config take effect on next boot
#wr
#reload
Proceed with reload? [confirm]y
If you did not purchase the licenses, it will just be and Eval
#sh license
Index 1 Feature: appxk9
        Period left: 8  weeks 4  days
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA accepted
        License Count: Non-Counted
        License Priority: Low
