7606S ordering
Sohrab Kasraeian Fard
Community Member
Dear All,
We are looking to order multiple Cisco 7606 chassis for multiple sites and each chassis should have two supervisor engine 720-3cxl and two power supply; now I'm wondering if I'm trying to put order for 7606S-720CXL-P what would I get with this part number?
Based on my search it should contain "1x Cisco 7606S 6 slot chassis,  2x SE 720-3CXL,  2x PS".
Is this the right part number for ordering or I'd need to order chassis separately from above part number?
Thanks in advance for your help and support
Best regards
below is the link you should refer to in order to get detail of the router specification and part numbers.
http://www.cisco.com/c/en/us/products/collateral/routers/7606-router/product_data_sheet0900aecd8057f3c8.html
http://www.cisco.com/c/en/us/products/collateral/routers/7606-router/product_data_sheet09186a0080088773.html
regards,
-Do rate helpful posts.
Hi venperum,
I checked both links you kindly sent but as I'm only looking for 7606-S so only first link is usable and also the part-number/bundle I mentioned above was not mentioned there, below I've put two links to other site as I find the part number there as well.
7606S-720CXL-R
7606S-720CXL-P
