827 gets ip and dns from server but interface does not work
I have an 827 (I know its old)  I have everything working from the router its self, I can ping out to ip and to domain names everything works it get the ip and dns dynamicly from the isp (verizon.)
However the interfaces do not get the dns server info i can't ping out to a domain name though it.  I can ping out to an outside ip address.
What did i miss in this, I know i am so close to getting this working.
The config follows (edited for password removal and i will secure it once this is working):
version 12.4
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
vpdn enable
interface Ethernet0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
interface ATM0.35 point-to-point
pvc 0/35
  pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname (removed)
ppp chap password (removed)
ppp pap sent-username (removed)
ppp ipcp dns request accept
ppp ipcp wins request accept
ppp ipcp route default
ppp ipcp address accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip nat inside source list 10 interface Dialer1 overload
access-list 10 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
logging synchronous
stopbits 1
line vty 0 4
login
scheduler max-task-time 5000
scheduler interval 5000
end
this is what i get if i ping from another device through it
Internet-Router#ping www.google.com
Translating "www.google.com"...domain server (192.168.0.1)
% Unrecognized host or address, or protocol not running.
but if i go from the router its self it works fine
Never mind, silly me was missing the ip dns server command
jason.bliss
try addint the IP name-server command to point to another DNS server from global configuration mode:
en
config t
ip name-server 4.1.1.1
end
