861-W Traffic Coming in and NAT/PAT
ardy
Hello All:
I am slowley getting this router configured........I am up and running, Thanks to this group.  Traffic from All nodes inside can go outside.  My next step is to configure traffic coming in to go to my server.  I have Web, FTP, SMTP and POP running on the same server in my LAN.  I need to us NAT/PAT to direct incoming traffic to it.  I belive I have this done correctly,  but obviously not........The configuration is attached.  any help is appriciated.
I only have port 80 configured in the config file,  if I can get that to work the rest would be the same........
Any help is appriciated.....
Ardy
cadet alain
ip nat source static tcp 192.168.1.3 80 24.x.x.2 80 extendable
Was this IP address assigned to you? Otherwise it won't work just use the IP address of 24.x.x.3
Regards.
Alain.
