871 high CPU utilization
catalin.stan
I have a 871 and when I'm downloading a bigger file (over 100 MB) or uploading via FTP the CPU goes to 99%.
I have tested this with basic configuration (only nat and dhcp service configured). I have install the latest IOS version that is supported on the router (c870-advipservicesk9-mz.124-24.T8.bin) but I still have the same problem.
Can someone please let me know if this is a normal behavior for 871. Will a flash/RAM upgrade will help?
Thank you
35 Replies 35
Seb Rupik
Hi Catalin,
During one of these high CPU states, what is the output of:
show proc cpu sorted
show proc cpu sorted 1min
cheers,
Seb.
Hi Seb,
Thank you for your reply.
Here is the output:
Router#sh proc cpu sorted
CPU utilization for five seconds: 89%/87%; one minute: 71%; five minutes: 25%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  49       48046      377383        127  0.63%  0.87%  0.35%   0 COLLECT STAT COU
120        1144     2680526          0  0.07%  0.03%  0.01%   0 HQF Shaper Backg
  77       18078       55311        326  0.07%  0.11%  0.10%   0 IP Input
121         464      751995          0  0.07%  0.01%  0.00%   0 RBSCP Background
  85        7452       38960        191  0.07%  0.01%  0.00%   0 Spanning Tree
111        1272      116689         10  0.07%  0.00%  0.00%   0 CEF: IPv4 proces
   6           0           2          0  0.00%  0.00%  0.00%   0 Timers
   5           4           5        800  0.00%  0.00%  0.00%   0 Pool Manager
   7           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
   8       13229       41788        316  0.00%  0.04%  0.06%   0 ARP Input
  11           0           2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
   9          76       78717          0  0.00%  0.00%  0.00%   0 ARP Background
   2        1420       15058         94  0.00%  0.00%  0.00%   0 Load Meter
  10           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
   4      748895       42062      17804  0.00%  0.79%  0.94%   0 Check heaps
  16          16          70        228  0.00%  0.00%  0.00%   0 EEM ED Syslog
  17           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  18           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  19           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  12           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
   3        4457         412      10817  0.00%  0.03%  0.02%   0 Exec
  22           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  23           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  24           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  13           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  14           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  27           0           1          0  0.00%  0.00%  0.00%   0 IDB Work
  15           0           2          0  0.00%  0.00%  0.00%   0 Entity MIB API
  29          32       75243          0  0.00%  0.00%  0.00%   0 TTY Background
  20           0           2          0  0.00%  0.00%  0.00%   0 SMART
  31           0           6          0  0.00%  0.00%  0.00%   0 IF-MGR control p
  32           0          20          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  33           0           7          0  0.00%  0.00%  0.00%   0 Collection proce
  34           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  35           0           2          0  0.00%  0.00%  0.00%   0 AggMgr Process
  36           0           1          0  0.00%  0.00%  0.00%   0 Token Daemon
  37           0           1          0  0.00%  0.00%  0.00%   0 Transport Port A
  38          28       22583          1  0.00%  0.00%  0.00%   0 HC Counter Timer
  21         200       75280          2  0.00%  0.00%  0.00%   0 GraphIt
  40         224      501887          0  0.00%  0.00%  0.00%   0 WLAN LED Timers
  41           0           2          0  0.00%  0.00%  0.00%   0 AUX
  25           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  43           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  44          20          11       1818  0.00%  0.00%  0.00%   0 USB Startup
  45        5249       65464         80  0.00%  0.00%  0.00%   0 Net Input
  46          84       15063          5  0.00%  0.00%  0.00%   0 Compute load avg
  47       20197        1282      15754  0.00%  0.02%  0.00%   0 Per-minute Jobs
  48          12           6       2000  0.00%  0.00%  0.00%   0 Switch Link Moni
  26         504       51912          9  0.00%  0.00%  0.00%   0 Net Background
  50           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  28           0          32          0  0.00%  0.00%  0.00%   0 Logger
  52          16       75319          0  0.00%  0.00%  0.00%   0 Crypto Device Up
  53           0           1          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
  54           0           1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
  30         396       75329          5  0.00%  0.00%  0.00%   0 Per-Second Jobs
  56           0           2          0  0.00%  0.00%  0.00%   0 SEC BATCH
  57          28       75247          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  58           4           2       2000  0.00%  0.00%  0.00%   0 DTP Protocol
  59           4           6        666  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
  39           0           2          0  0.00%  0.00%  0.00%   0 LED Timers
  61           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
  62         116       75283          1  0.00%  0.00%  0.00%   0 linktest
  63           0           2          0  0.00%  0.00%  0.00%   0 Dot11 Mgmt & Ass
  64           0           2          0  0.00%  0.00%  0.00%   0 Dot11 aaa proces
  65           0        1256          0  0.00%  0.00%  0.00%   0 pmkid
  66           0           2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x
  67           0           1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth
  68           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  69           0           2          0  0.00%  0.00%  0.00%   0 AAA Server
  70           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  71           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  72         108        8798         12  0.00%  0.00%  0.00%   0 CDP Protocol
  73           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
  74           0           5          0  0.00%  0.00%  0.00%   0 ADJ resolve proc
  75          12           7       1714  0.00%  0.00%  0.00%   0 IP ARP Adjacency
  76           4           1       4000  0.00%  0.00%  0.00%   0 IP ARP Retry Age
  42          72           6      12000  0.00%  0.00%  0.00%   0 ESWPPM
  78           0           1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  79           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Echo event
  80           0           3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  82           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
  83           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  84           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Time
  51         204        1891        107  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  86           0          24          0  0.00%  0.00%  0.00%   0 SSM connection m
  87           0           1          0  0.00%  0.00%  0.00%   0 AC Switch
  88           0         252          0  0.00%  0.00%  0.00%   0 Authentication P
  89           0           1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
  90           0           2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
  91           0           2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
  92         152        1446        105  0.00%  0.00%  0.00%   0 IP Background
  93          32        1064         30  0.00%  0.00%  0.00%   0 IP RIB Update
  94           0           1          0  0.00%  0.00%  0.00%   0 L2X Data Daemon
  95           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  96           0           2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  97           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
  98           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
  99           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
100          56          74        756  0.00%  0.00%  0.00%   0 L2MM
101           0           1          0  0.00%  0.00%  0.00%   0 MRD
102         484        1952        247  0.00%  0.00%  0.00%   0 IGMPSN
  55         296          26      11384  0.00%  0.00%  0.00%   0 crypto engine pr
104           0           1          0  0.00%  0.00%  0.00%   0 TCP Protocols
105           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
106           0         252          0  0.00%  0.00%  0.00%   0 HTTP CORE
107           4        1511          2  0.00%  0.00%  0.00%   0 CEF background p
108           0           1          0  0.00%  0.00%  0.00%   0 SNMP Timers
109           0           1          0  0.00%  0.00%  0.00%   0 COPS
110           0           2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
   1          12          33        363  0.00%  0.00%  0.00%   0 Chunk Manager
112           0           4          0  0.00%  0.00%  0.00%   0 ADJ background
113           0           3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
114           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
115           8          91         87  0.00%  0.00%  0.00%   0 RARP Input
116           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
117           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
118           0           2          0  0.00%  0.00%  0.00%   0 PPP SSS
119           0           1          0  0.00%  0.00%  0.00%   0 MQC Flow Event B
  60           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
103           0           1          0  0.00%  0.00%  0.00%   0 TCP Timer
122           4           7        571  0.00%  0.00%  0.00%   0 SCTP Main Proces
123           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
124           0           1          0  0.00%  0.00%  0.00%   0 IPS Process
125           0           2          0  0.00%  0.00%  0.00%   0 IPS Auto Update
126           0           2          0  0.00%  0.00%  0.00%   0 SDEE Management
127         196      146914          1  0.00%  0.00%  0.00%   0 Inspect process
128           0         628          0  0.00%  0.00%  0.00%   0 DHCPD Timer
129           4        6019          0  0.00%  0.00%  0.00%   0 FW DP Inspect pr
130           0           1          0  0.00%  0.00%  0.00%   0 tHUB
131          80      146914          0  0.00%  0.00%  0.00%   0 CCE DP URLF cach
132           0           2          0  0.00%  0.00%  0.00%   0 URL filter proc
133           0           1          0  0.00%  0.00%  0.00%   0 Select Timers
134          32           2      16000  0.00%  0.00%  0.00%   0 HTTP Process
135           0           2          0  0.00%  0.00%  0.00%   0 CIFS API Process
136           4           2       2000  0.00%  0.00%  0.00%   0 CIFS Proxy Proce
137           4           1       4000  0.00%  0.00%  0.00%   0 Crypto HW Proc
139           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
140           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
141           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
142           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
143           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
144           0           2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
145           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
146           0           1          0  0.00%  0.00%  0.00%   0 FW_TEST_TRP
147           0           1          0  0.00%  0.00%  0.00%   0 EPM MAIN PROCESS
148           0           3          0  0.00%  0.00%  0.00%   0 Crypto WUI
149           0           2          0  0.00%  0.00%  0.00%   0 Crypto Support
150           0           1          0  0.00%  0.00%  0.00%   0 IPSECv6 PS Proc
151           0           4          0  0.00%  0.00%  0.00%   0 Crypto CA
152           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
153           0           1          0  0.00%  0.00%  0.00%   0 Key Proc
154           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
155       36149        2592      13946  0.00%  0.00%  0.00%   0 crypto sw pk pro
156           0           1          0  0.00%  0.00%  0.00%   0 Crypto INT
157           0           3          0  0.00%  0.00%  0.00%   0 Crypto IKE Dispa
158           4           3       1333  0.00%  0.00%  0.00%   0 Crypto IKMP
159           0           1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
160         148        3767         39  0.00%  0.00%  0.00%   0 IPSEC key engine
161           0           1          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
162           4           6        666  0.00%  0.00%  0.00%   0 Crypto ACL
163           0           1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
164           0           1          0  0.00%  0.00%  0.00%   0 GDOI GM Process
165           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY
166           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY AC
167          20       34977          0  0.00%  0.00%  0.00%   0 PM Callback
168           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
169           0           2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
170           4           2       2000  0.00%  0.00%  0.00%   0 EEM ED Resource
171           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Routing
172           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Track
173           0        7528          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
174           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
175           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
176           8        2353          3  0.00%  0.00%  0.00%   0 Crypto cTCP proc
177          28           2      14000  0.00%  0.00%  0.00%   0 VLAN Manager
178           0        1255          0  0.00%  0.00%  0.00%   0 DHCPD Database
179           4          52         76  0.00%  0.00%  0.00%   0 EEM Server
180           0           2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
181           0           3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
182           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
183           0           3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
184           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
185           4           3       1333  0.00%  0.00%  0.00%   0 EEM ED IOSWD
186           4           3       1333  0.00%  0.00%  0.00%   0 EEM ED Ipsla
187           0           3          0  0.00%  0.00%  0.00%   0 EEM ED None
188           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Nf
189           0           3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
190           0           1          0  0.00%  0.00%  0.00%   0 VPDN Test
191           0           3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
192           0           2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
193           0        1886          0  0.00%  0.00%  0.00%   0 EEM ED Timer
194           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Test
195           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Config
196           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Env
197           0          18          0  0.00%  0.00%  0.00%   0 Syslog
198           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
201           8          43        186  0.00%  0.00%  0.00%   0 SSH Event handle
202         168        1039        161  0.00%  0.00%  0.00%   0 DHCPD Receive
203         260       75287          3  0.00%  0.00%  0.00%   0 DHCP Client
205         445      146917          3  0.00%  0.00%  0.00%   0 IP NAT Ager
206           0           1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
207           0           1          0  0.00%  0.00%  0.00%   0 IP VFR proc
Router#sh proc cpu sorted 1min
CPU utilization for five seconds: 18%/17%; one minute: 17%; five minutes: 19%
   4      750096       42128      17805  0.00%  1.30%  1.01%   0 Check heaps
  49       48986      377900        129  0.55%  0.29%  0.29%   0 COLLECT STAT COU
  77       18210       55706        326  0.07%  0.07%  0.09%   0 IP Input
   8       13321       42023        316  0.07%  0.05%  0.05%   0 ARP Input
   3        4541         670       6777  0.00%  0.05%  0.03%   0 Exec
  47       20229        1284      15754  0.31%  0.03%  0.00%   0 Per-minute Jobs
  45        5281       65640         80  0.00%  0.00%  0.00%   0 Net Input
  26         512       51963          9  0.07%  0.00%  0.00%   0 Net Background
120        1168     2684138          0  0.00%  0.00%  0.00%   0 HQF Shaper Backg
   9          80       78824          1  0.00%  0.00%  0.00%   0 ARP Background
CPU utilization for five seconds: 91%/89%; one minute: 22%; five minutes: 20%
   4      750669       42135      17815  0.55%  1.24%  1.01%   0 Check heaps
  49       51082      377908        135  1.18%  0.37%  0.30%   0 COLLECT STAT COU
  77       18222       55709        327  0.00%  0.06%  0.08%   0 IP Input
   8       13353       42027        317  0.07%  0.05%  0.06%   0 ARP Input
   3        4793         677       7079  0.07%  0.05%  0.03%   0 Exec
  47       20229        1284      15754  0.00%  0.03%  0.00%   0 Per-minute Jobs
  45        5281       65642         80  0.00%  0.00%  0.00%   0 Net Input
   2        1480       15079         98  0.07%  0.00%  0.00%   0 Load Meter
  40         228      502581          0  0.07%  0.00%  0.00%   0 WLAN LED Timers
  30         504       75436          6  0.07%  0.00%  0.00%   0 Per-Second Jobs
  26         512       51963          9  0.00%  0.00%  0.00%   0 Net Background
120        1172     2684159          0  0.00%  0.00%  0.00%   0 HQF Shaper Backg
  21         200       75387          2  0.00%  0.00%  0.00%   0 GraphIt
  29          32       75349          0  0.00%  0.00%  0.00%   0 TTY Background
  38          28       22615          1  0.00%  0.00%  0.00%   0 HC Counter Timer
   9          80       78828          1  0.00%  0.00%  0.00%   0 ARP Background
  46          84       15084          5  0.00%  0.00%  0.00%   0 Compute load avg
  52          16       75426          0  0.00%  0.00%  0.00%   0 Crypto Device Up
  57          28       75353          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  62         116       75389          1  0.00%  0.00%  0.00%   0 linktest
  65           0        1258          0  0.00%  0.00%  0.00%   0 pmkid
  72         108        8813         12  0.00%  0.00%  0.00%   0 CDP Protocol
  51         204        1895        107  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  85        7460       39118        190  0.00%  0.00%  0.00%   0 Spanning Tree
  92         252        1448        174  0.00%  0.00%  0.00%   0 IP Background
  93          32        1066         30  0.00%  0.00%  0.00%   0 IP RIB Update
102         484        1956        247  0.00%  0.00%  0.00%   0 IGMPSN
107           4        1512          2  0.00%  0.00%  0.00%   0 CEF background p
111        1500      116852         12  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
121         476      753027          0  0.00%  0.00%  0.00%   0 RBSCP Background
127         296      147119          2  0.00%  0.00%  0.00%   0 Inspect process
128           0         629          0  0.00%  0.00%  0.00%   0 DHCPD Timer
129           4        6027          0  0.00%  0.00%  0.00%   0 FW DP Inspect pr
131          84      147119          0  0.00%  0.00%  0.00%   0 CCE DP URLF cach
160         148        3772         39  0.00%  0.00%  0.00%   0 IPSEC key engine
167          32       35030          0  0.00%  0.00%  0.00%   0 PM Callback
173           0        7538          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
176           8        2356          3  0.00%  0.00%  0.00%   0 Crypto cTCP proc
178           0        1257          0  0.00%  0.00%  0.00%   0 DHCPD Database
193           0        1889          0  0.00%  0.00%  0.00%   0 EEM ED Timer
203         260       75393          3  0.00%  0.00%  0.00%   0 DHCP Client
205         449      147122          3  0.00%  0.00%  0.00%   0 IP NAT Ager
Hi Catalin,
The line:
...indicates 89% of CPU usage is down to intterupts where the packets are being process switched as opposed to processing by CEF. The other 2% being made of running processes.
What is the output from:
show ip cef switching statistics
Also take a look at this document which will run you through some tests you can carry out:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
cheers,
Seb.
Hi Seb,
here is the output:
Router#sh ip cef switching statistics
       Reason                                Drop       Punt  Punt2Host
RP LES No route                        2226              0          1
RP LES Packet destined for us        0        38152          0
RP LES TTL expired                        0            0      26128
RP LES Features                           0               0        924
RP LES Unclassified reason        22334           0          0
RP LES Total                             24560      38152      27053
All    Total                                 24560      38152      27053
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Your CPU stats indicate most of your CPU is "interrupt" CPU, i.e. normal packet forwarding.
An 871 had only a 25 Kpps rate "engine".  Cisco recommends the 25 Kbps 860 series for only 4 Mbps of WAN bandwidth.
What's your aggregate bandwidth utilization when CPU tops out?
Hi Joseph,
Can you please tell me how do I check that ?
Try this command to show you the per interface pps on the router:
sh int summary
Router#sh inter summary
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface              IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* FastEthernet0            0     0    0     0 2582000  274 60000  107    0
* FastEthernet1            0     0    0     0 61000  107 2594000  270    0
  FastEthernet2            0     0    0     0     0    0     0    0    0
  FastEthernet3            0     0    0     0     0    0     0    0    0
  FastEthernet4            0     0    0     0     0    0     0    0    0
  NVI0                     0     0    0     0     0    0     0    0    0
* Vlan1                    0     0    0     0 2873000  306 56000  118    0
* Vlan192                  0     0    0     0 61000  118 2862000  299    0
Was that during a download and high CPU usage?
Yes
OK, what's the output from: sh int stats
...compare the ratio between 'Processor' and 'Total', to see what percentage of packets processed by the CPU.
Also the output from:
sh int fa0
sh int fa1
...look at the 'overrun' counter. A high number here would indicate an inerface that is stuggling to process the number of packets being processed.
If any of the above numbers are high, then this is highlighting a hardware limitation. So long as there aren't many packet drops, then this limitation will only manifest itself with increased latency.
Router#sh interfaces stats
FastEthernet0
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor      57707   69990129      21779    1412159
             Route cache          0          0          0          0
                   Total      57707   69990129      21779    1412159
FastEthernet1
               Processor      20422    1341906      53711   65306522
             Route cache          0          0          0          0
                   Total      20422    1341906      53711   65306522
FastEthernet2
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet3
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
Interface FastEthernet4 is disabled
Interface NVI0 is disabled
Vlan1
               Processor        222      63489         18       1629
             Route cache      73197   88759272      27702    1519940
                   Total      73419   88822761      27720    1521569
Vlan192
               Processor         94      17399         19       2646
             Route cache      27888    1692644      73693   89384507
                   Total      27982    1710043      73712   89387153
Router#sh int fa 0
FastEthernet0 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0019.e75b.1455 (bia 0019.e75b.1455)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 8/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  Last input 00:00:01, output never, output hang never
  Last clearing of "show interface" counters 00:00:40
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3354000 bits/sec, 353 packets/sec
  5 minute output rate 73000 bits/sec, 135 packets/sec
     121840 packets input, 148008746 bytes, 0 no buffer
     Received 124 broadcasts, 0 runts, 0 giants, 0 throttles
     46314 packets output, 2992014 bytes, 0 underruns
     2 unknown protocol drops
     0 lost carrier, 0 no carrier
Router#sh int fa 1
FastEthernet1 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0019.e75b.1456 (bia 0019.e75b.1456)
     reliability 255/255, txload 11/255, rxload 1/255
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:00:49
  5 minute input rate 103000 bits/sec, 190 packets/sec
  5 minute output rate 4675000 bits/sec, 485 packets/sec
     58198 packets input, 3774735 bytes, 0 no buffer
     Received 98 broadcasts, 0 runts, 0 giants, 0 throttles
     152620 packets output, 185746450 bytes, 0 underruns
     0 unknown protocol drops
Looks like every packet is handled by the processor:
FastEthernet0
             Route cache          0          0          0          0
FastEthernet1
             Route cache          0          0          0          0
...so to answer your original question, this appears to be normal behaviour!
OK. Thank you!
I see that the route cache for the interfaces vlan1 and vlan192 is very high. Is this the normal behavior ?
It's very strange that I can't download large files from ftp with this model.
Will an upgrade of RAM help ?
