877 and HSRP
asanemeterio
Want to be known if there is some problem between 877 with 12.4(2) IOS and HSRP protocol. In HSRP, this router has the standby role, but when the interface atm0 on master router fails, this router does not answer to the pings that do to themselves the IP of HSRP.
I review all bugs from this IOS and don't found any that resolve this question.
All configurations in both Cisco877 and cisco 1841 routes are correct.
Thanks for your help
6 Replies 6
Hola Augustín,
just to be sure, can you post the configurations of both routers ?
GP
Yes I'm sure, but the administrators have configured the standby HSRP in Vlan1 interface. Is possible this is the problem?
agusti
If the vlan 1 is configured as Layer 3 VLAN it should be ok....can u post he config?
hello,
I only can attach a partial configuration
- 877 -
interface Vlan1
description FHK094413F8
ip address 10.5.35.202 255.255.255.0
standby 1 ip 10.5.35.1
standby 1 priority 90
standby 1 preempt
standby 1 track ATM0 40
-1841 -
interface FastEthernet0/0
description "FCZ0938252M"
ip address 10.5.35.201 255.255.255.0
duplex auto
speed auto
standby 1 priority 110
standby 1 preempt
standby 1 track BVI1 40
The only option I have dubt is add "decrement" before 40 in the "standby 1 track BVI1 40" line.
thanks for your help
agusti
There seems to be a problem with the Active HSRP router listening for the virtual MAC address on vlan interfaces on the c877.
A workaround is to configure "standby use-bia" on the vlan interface so that HSRP uses the interface MAC address.
Also, the "decrement" keyword is optional.
Ian
Just want to stick my head in here and say that i had this issue too. When i used the "Standby use-bia" on both routers. it workied just fine.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
