A syn flood attack
pesanchez2002
hi,
I receive the next message in unix, my webserver, What the meaning?
What i can do?
"warning: high tcp connect timeout rate! system (port 443) may be under a syn flood attack"
Giuseppe Larosa
Hello Pedro,
if you have an edge router you can use TCP intercept feature to defend your server.
see
http://www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_cfg_tcp_intercpt_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
Thanks by your answer,
I don't have router edge.
I have the next connection
pix---sw---webserver
internet
Internet connect with sw
Hello Pedro,
if the pix is not on the path to/from internet you cannot do anything.
You should have the webserver on an DMZ (third leg/interface) of pix.
doing so you could protect the server.
By the way, the message says:
port 443 that is
Protocol / Name: https
If you don't need https you can close the service on the web server.
if you are using https this cannot be done.
I would suggest you to review the DMZ and to have it protected by the pix that can provide features similar to TCP intercept.
Hope to help
Giuseppe
