access list doesn't get hits
katrin1701
I've got an
access-list
that I'm using for NAT and while it is working, I can't see any hits.
I've seen other posts here that it depends on processing via Hard- or Software.
How do I know if this might be the case?
I'd like to be able to see things in that
access-list
in the log, for examle as in
deny any any log
but that doesn't seem to work either.
Is there any way to make that visible?
sorry but the command I mentioned before is work only for SW not for router
show access-list
hardware count
""NAT does not support access control lists (ACLs) with the log option. The same functionality can be achieved by using one of the following options:
  • By having a physical interface or virtual LAN (VLAN) with the logging option
  • By using NetFlow""
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-16/nat-xe-16-book/iadnat-monmain.html
NAT ACL not support Log as cisco mention in guide.
9 Replies 9
 You did not mention the device  but on the Label of your thread it shows ISR4000. This device runs IOS XE.
Take a look on this link
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_data_acl/configuration/xe-16-8/sec-data-acl-xe-16-8-book/sec-dply-clr-ald-acl-xe.html
it is an ISR4451 version 17.3
It displays logs for other
access-lists
but not for the NAT
access-list
It might be due to the fact that the outgoing tagged interface are virtual-access interfaces, via a virtual-template, which has ip nat outside as a parameter.
if it ISR4451 IOS-XE then there is command I think help you.
if this is SW cat9000 then there is chance that NAT is done in TCAM,
when NAT (and it ACL) done in TCAM there is no log.
how does one find ot if it is done in TCAM?
Would that also explain why i can't add remarks to my
access-lists
show access-list
hardware count
shame, it used to work on a
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.2(4)M7, RELEASE SOFTWARE (fc2)
I don't have the license for NetFlow it seems (but on the first glance it seems way too complicated for my purposes)
and logging on the interface offers
link-status UPDOWN and CHANGE messages
nfas-status NFAS D-channel status messages
subif-link-status Sub-interface UPDOWN and CHANGE messages
which doesn't seem to be what I want either.
I'll just make do without it, I think. At least for now.
Hello
The nat ACL is used for the rtr to call upon so to translate the address(s) specified in it, so I am not sure why you would want to log that particular
access-list
as whatever is specified is what you wish to translate.
Kind Regards
Paul
I don't understand what a Response Time Reporter has do do with it, so I can't comment on that.
If the system is running normally I don't need to log anything, but just in case I'd like to be able to add a log to look for problems, afaik that's what the option log is used for.
I'd also be happier if I had hits, so I can see that the ACL is in use and working.
I don't understand why it shouldn't be possible.
