Access WEB server from LAN
petrutz_21
Level 2
Level 2
I have a Router 2801
What conf should i make to access the webserver from the same LAN.
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.63
ip dhcp excluded-address 192.168.1.192 192.168.1.254
ip dhcp pool xxx
   network 192.168.1.0 255.255.255.0
   domain-name xxx.com
   default-router 192.168.1.1
   dns-server 193.226.128.1 193.226.128.129
   lease 20
ip domain name xxx.com
ip name-server 95.77.94.77
ip name-server 213.154.124.1
ip name-server 193.231.252.1
ip name-server 78.96.7.7
interface FastEthernet0/0
description isp1
ip address xxx.xxx.xxx.118 255.255.255.128
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description isp2
ip address xxx.xxx.xxx.206 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/3/0
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface FastEthernet0/3/3
interface Vlan1
description xxx
ip nat inside
rate-limit output access-group 101 8000000 3000000 7000000 conform-action transmit exceed-action drop
rate-limit output access-group 102 8000000 3000000 7000000 conform-action transmit exceed-action drop
ip route 0.0.0.0 0.0.0.0 isp1
ip route 0.0.0.0 0.0.0.0 isp2 10
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.1.222 80 interface FastEthernet0/0 8080
ip nat inside source route-map isp2 interface FastEthernet0/1 overload
ip nat inside source route-map isp1 interface FastEthernet0/0 overload
ip access-list extended BLOCK_PORTS
deny   tcp any eq smtp any
permit ip any any
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit tcp any eq www 192.168.1.64 0.0.0.63
access-list 102 permit tcp any eq www 192.168.1.128 0.0.0.63
route-map isp2 permit 10
match ip address 100
match interface FastEthernet0/1
route-map isp1 permit 10
match interface FastEthernet0/0
I've done:
ip nat inside source static tcp 192.168.1.222 80 interface fastethernet0/0 8080
for accessing the webserver from the internet.
I need to access the webserver troough the public from tha LAN.
Thanks.
6 Replies 6
Giuseppe Larosa
Hello Toma,
if you mean that you would like to access the web server from the internal LAN you can access it on the private address
192.168.1.222.
if you would like to access from inside using the outside IP address I'm afraid this can be a problem as NAT works when a traffic flow crosses from inside interface to outside interface
Is it working the NAT rule when you access from outside world on port 8080?
Hope to help
Giuseppe
Hi Giuseppe,
From the internet when I type publicaddress:8080 it's working but when I try tu ccess from the LAN it doesen't work; just if I type 192.168.1.222.
I want to access it from the LAN using the public ip address.
Thanks.
.Hello Toma,
I know it would be handy if supported, but actually what happens is that you are attempting to access the router itself on port TCP 8080 on ip address associated with WAN interface from internal LAN: it doesn't trigger the NAT translation so it doesn't work.
You can check this with show ip nat translations or even with debug ip nat
From networking point of view you should use private IP address when you are in the private internal network=LAN, that is the way NAT is designed to work.
Hope to help
Giuseppe
petrutz_21
Level 2
Level 2
Any other suggestion on how to make this work from the inside lan ?
I've been searching on google and i still can find a good solution.
Why we  can make this work with a cheap router and with a cisco router is so complicated ?
this not possible because hairpinning ( the feature you want to use) is not implemented on Cisco routers but DNS rewrite also called DNS doctoring should be implemented and so if this is the case you must have a public DNS server with your  A record on it and then you will access the server with its FQDN either from outside or inside( in which case the router will rewrite the DNS reply to the inside IP address of the server).
Regards.
Alain
Hi Cadet Alain,
But what about NAT on a stick. I'm not quite sure that this can be aply in this case. What do you know about this ?
Network Address Translation on a StickNAT
