accessing internet
ChRiStEw1234
Level 2
Level 2
hi im trying to set up my cisco lab to access the internet through my virgin home router,i have turned on modem mode and it gives my router 1 an ip add,i have also set up nat with overload,i also see the route in my routing tables of other routers. frim pc 3 that is right across the other side of the network i can ping 4.2.2.2 but not google.com,from my r1 which is the router connected to my modem i can ping 4.2.2.2 and google.com no problem,and when i do sh ip nat translations it shows the nat working,but non of the pcs can get any web pages.also have default route to internet interface,no other access-lists just the nat any ideas
also from all pcs i can type in ip add into web browser and access the site,on each router i have done the command ip name server 4.2.2.2
thanks tewy
2 Accepted Solutions
Hi Chris,
Are your PCs able to use a DNS server, did you set a DNS server on ur PCs or have the option set, in case of using DHCP server for addressing?
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
from the pc, can you ping to 8.8.8.8 ? if yes, then try to change your dns to this ip. its google's dns
regards,
10 Replies 10
handoko wiyanto
Level 6
Level 6
hi Chris,
would you mind giving us the network diagram? it'll help a lot.
regards,
ChRiStEw1234
Level 2
Level 2
hi can u give me the ip add of these forums as using the pcs for the lab an not sure how to add diagram through iphone,with the ip address i can access the forums on pc then and add the diagram and any show commands needed
its https://supportforums.cisco.com
and the thread is under Wan, Routing and Switching
regards,
ChRiStEw1234
Level 2
Level 2
hi no i mean the actual ip address it seems to be with the dns as if i type google.com i get cant find server but if i type 173.194.34.160(google.com s ip add)i can access the page
thanks chris
ChRiStEw1234
Level 2
Level 2
will reset up pcs an post diagram
thanks
Hi Chris,
Soroush.
Hope it Helps!
Soroush.
ChRiStEw1234
Level 2
Level 2
hi i hadnt setup dns on the pcs but after u replied i setup dns on pc to isp dns and secondary dns 4.2.2.2 but it still doesnt work
thanks chris
regards,
ChRiStEw1234
Level 2
Level 2
hi no i think theres somthing else goin on now as i cant ping trace or access using ip addresses anymore,will try get it back how it was and try ur suggestions,will rate if i suss it and ask if i dont thanks for all your help
thanks chris
ChRiStEw1234
Level 2
Level 2
hi guys thanks for all your help it was i hadnt set up dns on pcs
thanks chris
