ACL clarification..
ittechk4u1
Level 7
Level 7
Hello experts,
As we are implementing MPLS on few location (Not all) so we need to filter VIDEO Application traffic and sent it over to MPLS ,rest traffic will go via Internet VPN.
Here is my config:
Headquarter Router :
interface GigabitEthernet0/2
description *** MPLS ***
ip address 172.24.18.1 255.255.255.248
interface GigabitEthernet0/1
description *** LAN connection ***
ip address 10.18.2.4 255.255.255.0
ip policy route-map IDEO
route-map VIDEO permit 5
description *** only Video Traffic Allowed ***
match ip address VIDEO
set ip next-hop verify-availability 172.24.18.6 1 track 556
route-map VIDEO permit 6
ip access-list extended VIDEO
remark *** RTP ****
permit udp any any range 16384 32767
permit udp any range 16384 32767 any
deny ip any any
ip sla 556
icmp-echo 172.24.18.6 source-interface GigabitEthernet0/2
threshold 2
timeout 1000
frequency 3
ip sla schedule 556 life forever start-time now
track 556 ip sla 556 reachability
Branch Router:
int gig0/1
desc *** Internet ISP1 ***
IP address xxx.xxx.xxx.xxx/29
int gig0/2
des *** To MPLS ***
ip address 172.24.56.1 255.255.255.248
int vlan 6
desc *** LAN ***
ip address 10.56.xx.xx/24
ip policy route-map VIDEO
description *** only Video Traffic ***
set ip next-hop verify-availability 172.24.56.2 track 56
route-map SAP_VIDEO permit 6
remark *** RTP ****
deny ip any any
ip sla 56
icmp-echo 172.24.56.2 source-interface GigabitEthernet0/2
threshold 2
timeout 1000
frequency 3
ip sla schedule 56 life forever start-time now
track 56 ip sla 56 reachability
My main concern is on HQ router as all video traffic will be send to MPLS(which is my probelm)!!
How can I send the video traffic to few location whcih are using MPLs not others.
MPLS location : 10.56.xx.xx
Without MPLS: 10.48.xx.xx
hkkalra
Level 3
Level 3
As per my understanding you need to define in the ACL on the HQ to only match traffic that is going to some of your branches to use MPLS. You are defining the path using the "set ip next-hop"command.
I would recommend you to make changes in the ACL VIDEO to only match traffic which is destined to the branch office which are using MPLS.
Instead of using:
ip access-list extended SAP-VIDEO
remark *** RTP ****
deny ip any any
You can use something like this where I am taking 192.168.0.0/16 and 10.0.0.0/8 as examples of remote branches using MPLS:
remark *** RTP ****
permit udp any 192.168.0.0 255.255.0.0 range 16384 32767
permit udp any range 16384 32767 192.168.0.0 255.255.0.0
permit udp any 10.0.0.0 255.0.0.0 range 16384 32767
permit udp any range 16384 32767 10.0.0.0 255.0.0.0
deny ip any any
This would only match traffic for these two branches and send it MPLS and rest of the traffic will go through your normal routing (VPN I am assuming).
Hope my understanding is correct and this is helpful.
hkkalra
Level 3
Level 3
Instead of using:
remark *** RTP ****
deny ip any any
remark *** RTP ****
deny ip any any
I agree with you but the problem is I have a very long ACL(40 lines) and 6 location are using MPLS means total lines will be (40*6= 240 lines).
Is there any other solution ???
You need a factor to differentiate between the traffic going to the Branch office with MPLS from the traffic going to the Branch without MPLS. From your requirement it is only possible to do that using IP addresses.
