ACL in VLAN
Soumik Mondal
Hi All
I have to configure some new VLAN in our office
VLAN-1 --Server                 192.168.0.0/24
VLAN-2 --Systems              192.168.1.0/24
VLAN-3 Project-1                 192.168.2.0/24
VLAN-4 project-2                  192.168.3.0.24
I want Project-1 and Project-2 have access to server VLAN only.
Accees list extented Project 1
deny IP 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255------------- Deny System VLAN
deny IP 192.168.2.0 0.0.0.255 192.168.3.0 0.0.255---------------Deny project 2 VLAN
permit IP any any
But problem is that system VLAN should access to all VLAN,but no VLAN should access system VLAN.With this access list the access of system VLAn to other Vlan is blocked.Can any body suggest me something.We are using 4500 as L3 switch and 2960 as L2.............
8 Replies 8
Seb Rupik
Hi Soumik,
If I've read your requiremnt correclty, you'll want the following config on your 4500. Obviously change the SVI numbers as required:
interface vlan 1
desc server vlan
interface vlan 2
desc systems vlan
ip access-group 102 in
interface vlan 3
desc project1 vlan
ip access-group 103 in
interface vlan 4
desc project2 vlan
ip access-group 104 in
access-list ext 102 deny 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255 remark deny server
access-list ext 102 deny 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255 remark deny project1
access-list ext 102 deny 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255 remark deny project2
access-list ext 103 deny 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255 remark deny server
access-list ext 103 deny 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255 remark deny project2
access-list ext 104 deny 192.168.0.0 0.0.0.255 192.168.3.0 0.0.0.255 remark deny server
access-list ext 104 deny 192.168.2.0 0.0.0.255 192.168.3.0 0.0.0.255 remark deny project1
cheers,
Seb.
Hi Seb
I think I am unable to describe my requirement properly.
VLAN -1        All access
VLAN- 2        All access
VLAN-3         Only Server VLan.No other VLAN
VLAN-4        Only Server VLan.No other VLAN
interface vlan 2
desc systems vlan
This will deny project 1 and project 2 to access  system Vlan and vice versa .But system Vlan needs access to Project1 and Project 2 Vlan.This is my requirements.
All ACL´s have a standard entry at the end (deny any any) you cannot see it, you must write minimum one permit entry.
Like: access-list ext 102 permit 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
or like: permit any any
Hi Soumik,
As Markus mentioned, I forgot you need to add:
permit ip any any
...at the end of each of the ACL, to overirde the implied 'deny any any'.
As the access-group statement is inbound, then the suggested ACLs should work. ACL 102, will deny VLANs 1 and 2 in. Likewise, ACLs 103 and 104 do not deny the systems VLAN, so the suggested 'permit any any' will let that traffic in.
So use the following:
access-list ext 102 deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255 remark deny server
access-list ext 102 deny ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255 remark deny project1
access-list ext 102 deny ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255 remark deny project2#
access-list ext 102 permit ip any any
access-list ext 103 deny ip 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255 remark deny server
access-list ext 103 deny ip 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255 remark deny project2
access-list ext 103 permit ip any any
access-list ext 104 deny ip 192.168.0.0 0.0.0.255 192.168.3.0 0.0.0.255 remark deny server
access-list ext 104 deny ip 192.168.2.0 0.0.0.255 192.168.3.0 0.0.0.255 remark deny project1
access-list ext 104 permit ip any any
cheers,
Seb.
How to configure one way traffic.
Vlan 2 can access Vlan 3 and Vlan 4
But Vlan 3 and Vlan 4 cann't access Vlan 2
ACLs are stateless and communication is bidirectional in IP so you'll need to permit return traffic from VLAN3 and VLAN4 for VLAN2 to access them and deny traffic originated in VLAN 3 and VLAN 4.
For return TCP traffic you have the established keyword, for ICMP you'll need to permit the echo-replies and time-exceeded and port-unreachable at least and for UDP you'll have to permit the possible UDP services reply( like DNS 53,DHCP 67).
Alain
Hi cadet
Yes , this is the right approch to configure this.Can you help me with some configuration example or link.....
some example:
vlan2:192.168.2.0/24
vlan3: 192.168.3.0/24
vlan4:192.168.4.0/24
vlan2 can access vlan 3 and vlan 4 but none of these can access vlan 2.vlan 3 can access vlan 4 and vlan 4 can access vlan 3.
ip access-list extended vlan2-34
permit ip 192.168.2.0 0.0.0.255 192.168.3.0 0.0.0.255
permit ip 192.168.2.0 0.0.0.255 192.168.4.0 0.0.0.255
ip access-list extended vlan3-42
permit ip 192.168.3.0 0.0.0.255 192.168.4.0 0.0.0.255
permit icmp 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255 echo-reply
permit icmp 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255 time-exceeded
permit icmp 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255 port-unreachable
permit tcp 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255 established
permit udp 192.168.3.0 0.0.0.255 eq 53 192.168.2.0 0.0.0.255
permit udp 192.168.3.0 0.0.0.255 eq 67 192.168.2.0 0.0.0.255
ip access-list extended vlan4-32
permit ip 192.168.4.0 0.0.0.255 192.168.3.0 0.0.0.255
permit icmp 192.168.4.0 0.0.0.255 192.168.2.0 0.0.0.255 echo-reply
permit icmp 192.168.4.0 0.0.0.255 192.168.2.0 0.0.0.255 time-exceeded
permit icmp 192.168.4.0 0.0.0.255 192.168.2.0 0.0.0.255 port-unreachable
permit tcp 192.168.4.0 0.0.0.255 192.168.2.0 0.0.0.255 established
permit udp 192.168.4.0 0.0.0.255 eq 53 192.168.2.0 0.0.0.255
permit udp 192.168.4.0 0.0.0.255 eq 67 192.168.2.0 0.0.0.255
int vlan 2
ip access-group vlan2-34 in
int vlan 3
ip access-group vlan3-42 in
int vlan 4
ip access-group vlan4-32 in
Alain
