ACL Nestingvs Service Policy
SivaKesava
Hi all,
Consider two extended ACLs (extended_ACL1, extended_ACL2). If I want to apply both of them (allowed by any one of them) on the input for an interface I have to create a new ACL(merged_Extended) and then apply using
"ip access-group merged_Extended in"
Is there any other better way?
Consider the same scenario where both the ACLs are to be applied. If I create a  class-maps as follows:
class-map match-any map1
   match access-group name extended_ACL1
   match access-group name extended_ACL2
Then create a policy-map as:
policy-map merged
   class map1
     pass
   class class-default
     drop
Now If I apply these to the interface as :
interface TenGigabitEthernet1/4
  service-policy input merged
Is this a right approach? Can it be done like this?
Hello
My understanding this wont work, The interface will it probably take the policy but the router wont process it.
Whats wrong using just the one extended acl to do the job?
Kind Regards
Paul
Consider the router config where we have defined extended_ACL1 and extended_ACL2 and use them on some interfaces. For another interface, I want to apply both of them(allowed by any one of the ACL) so I have to now create another extended ACL by copying lines from extended_ACL1 and extended_ACL2 and putting them together. This increases the config text so I was asking if there are any alternatives(like the one I suggested)?
ip access-list extended_ACL1
permit ip ....
permit ip ....
ip access-list extended_ACL2
permit udp ....
permit udp ....
ip access-list extended_merged
permit ip ....
permit ip ....
permit udp ...
permit udp ...
Hello
As far as I am aware I dont think there is, but that's not to say there isnt one.
Kind Regards
Paul
