ACL to deny telnet from any host on subnet
Deanmikawa
Hello, I need to configure an ACL to deny telnet from any host on subnet 135.79.40.0/24 to anything on other subnets.
I think I want to do something like this:
access-list 150 deny tcp host 135.79.40.0 0.0.0.255 any eq telnet
But I am not getting any results.... How can I configure my ACL to deny telnet requests from hosts on that subnet?
Attatched is a map of the network I am currently working with.  The goal is to deny telnet attempts from host E into router b and c, switch a and b.
Thank you,
Dean
11 Replies 11
Julio E. Moisa
Have you tried to configure the following parameters on Router A' s0/0 interface?
**Also remove the host word, it is used when you are specifying a /32 IP address. There are 2 ways to configure a host, example:
access-list 150 deny tcp host 135.79.40.10 any eq telnet
or
access-list 150 deny tcp 135.79.40.10 0.0.0.0 any eq telnet
Now try this configuration on Router A's serial 0/0 interface
access-list 150 deny tcp 135.79.40.0 0.0.0.255 any eq telnet
access-list 150 permit ip any any
interface s0/0
ip access-group 150 out
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
gives me incomplete command
access-list 150 deny tcp 135.79.40.0 0.0.0.255 any eq telnet ?
gives me unrecognized command
I have also tried
RouterC(config)#access-list 150 deny tcp host 135.79.40.0 0.0.0.255 135.79.10.2 eq telnet
RouterC(config)#access-list 150 permit ip any any
RouterC(config)#int s0/1
RouterC(config-if)#ip access-group 150 in
and it blocks telnet into router b but allows telnet into everything else
Try with on RA's Serial 0/0
access-list 150 deny tcp 135.79.40.0 0.0.0.255 any eq 23
int s0/0
After configuring
int s0/0
I am still able to telnet into the routers from Host e
Have you verified if the configuration is not after of a permit any any on router A? Try to remove the ACL 150 and please try again.
Also you can check the matches using show access-list 150.
ok i have tried again with a fresh router with no configs.
same result, I am able to telnet into the routers.
posted is a result of show access-list 150 command, doesn't not yield response though.
You should execute the command on privilege user prompt. (#)
Ok results:
RouterC#showaccess-list 150
Extended IP access list 150
       permit ip any any
This is after a fresh attempt and am still able to telnet
Try this lines just to verify because I dont see hits
no access-list 150
access-list 150 deny tcp any any eq 23
int serial 0/0
Here are results up to first incomplete command: access-list 150 deny tcp any any eq 23
I have not received any error message, are you using bossom?
