ADSL Data rate command
rasoftware
Hi I'm looking for a command in the IOS to indicate the negotiated data rate with the DSLAM for an ADSL connection but can't find one.
I'm trouble shooting an ADSL max issue and this would be useful.
Andy Robinson
"show dsl interface atm0" should be the command that you need to show the upstream and downstream sync speeds. You will need to substitute "atm0" if your adsl module is in a different slot on the router
