ASA routing issues
s.mallonee
Ok,
So having some issues with routing on a ASA.  Not sure if the ASA can do what we are trying to do with it however it was the equipment we have on hand and was asked to attempt to make it work.
Below is the config of the ASA.  The problem I am having is that the 10.116.0.0/19 cannot get to the 10.51.0.0/16.  The Akmaaq-LAN interface can ping down to 10.51.0.0/16 but nothing in the NS-LAN can.  Can anyone see why I may be having this issue?
Thanks in advance.
Sean
sh run
: Saved
ASA Version 8.0(4)
hostname AKQ-AK-GW1
enable password U2E6Nz68OvO4VlFL encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
description GCI WAN Network
nameif GCI-WAN
security-level 0
ip address 10.10.10.10 255.255.255.0
interface Ethernet0/1
description NanaServices LAN
nameif NS-LAN
security-level 100
ip address 10.116.0.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
description Akmaaq LAN tie
nameif Akmaaq-LAN
security-level 100
ip address 192.168.70.7 255.255.255.0
interface Management0/0
nameif management
security-level 100
no ip address
management-only
ftp mode passive
same-security-traffic permit inter-interface
pager lines 24
logging asdm informational
mtu GCI-WAN 1500
mtu NS-LAN 1500
mtu Akmaaq-LAN 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (GCI-WAN) 1 interface
nat (NS-LAN) 1 0.0.0.0 0.0.0.0
static (NS-LAN,Akmaaq-LAN) 10.116.0.0 10.116.0.0 netmask 255.255.224.0
route GCI-WAN 0.0.0.0 0.0.0.0 69.178.0.1 1
route Akmaaq-LAN 10.51.0.0 255.255.0.0 192.168.70.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.70.101 255.255.255.255 Akmaaq-LAN
ssh timeout 10
ssh version 2
console timeout 0
dhcpd dns 209.165.131.12 209.165.131.13
dhcpd lease 86400
dhcpd address 10.116.0.50-10.116.0.100 NS-LAN
dhcpd enable NS-LAN
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username smallonee password A2NSLOjGBhWoAs/d encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:8f3000929b1e2902f2885254ed4bdbee
: end
Richard Burts
Sean
The first thing that I notice is that you refer to the source as 10.116.0.0/19. But the ASA has the interface ip address as 10.116.0.1 255.255.255.0. So the ASA only knows how to get to a /24 and not a /19.
If that is not the issue then I would ask questions like is the next hop for the route to 10.51.0.0/16 of 192.168.70.1 reachable.
And if that is not the issue then I would observe that the ASA has a route to 10.51.0.0/16 and ask whether that site has a correct route back to 10.116.0.0?
Rick
Rick
