ASR Router with BGP Neighbours and Failover
mahesh18
Level 6
Level 6
We have ASR Routers with 3 BGP neighbour's which are 3 different ISP's.
We are learning routes from all of them
From ISP 1 we are learning full Internet Routing table.
IF we lose physical link to ISP 1 will our Router learn all the routes from ISP 2 and 3?
We do not have any link monitoring configured on physical links connecting to the 3 ISP's
3 Accepted Solutions
Hello Mahesh,
just look at the output of show run | begin router bgp
if you see commands that sets local preference per neighbor  or any route-map applied in direction in per neighbor some form of manipulation is configured otherwise simply BGP uses the default order of criteria to choice the best path.
Hope to help
Giuseppe
Based on your previous output, there is no local preference or whatsoever. The route chosen is based on as-path.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hello Mahesh,
the route-maps are not applied to any neighbor so no type of route manipulation is occurring in this moment in your router.
You have a route-map that could be used to increase the local-preference to 150 for all received routes if you add a command like
neighbor <IP-address-ebGP-neighbor> route-map set-local-pre in
under router bgp or router bgp address-family ipv4-unicast
The use of a command like the one proposed above should be considered only for the eBGP neighbors that are sending you partial BGP routes like ISP2 and ISP3.
As I have written in another thread I would give local preference 200 to ISP3 that gives you a small number of routes, then local preference 150 to ISP2 that sends you more routes. You can leave ISP1 and the iBGP neighbor with default settings of local-preference 100.
However, you need to consider the current link usage of links towards ISP3, ISP2 and ISP1 and their effective speed that can be different. Likely ISP1 has a link with higher bandwidth.
An higher local-preference can make a prefix with a longer AS path preferred because local preference is considered before AS path length in BGP best path selection.
At the moment as noted by Francesco no form of route manipulation is occurring in your router.
Hope to help
Giuseppe
21 Replies 21
Francesco Molino
You said you have 3 bgp peering with 3 ISPs.
From 1 you're learning the full internet table. What about with the 2 others?
The routing table will install prefixes learned from the 2 others when isp1 will be down but depending on what you're learning you may have only a default route.
How is your bgp configuration? Do you have done mechanisms to prioritize prefixes over isp1 ?
Can you share the configuration and output of sh ip bgp summary (if your ISPs are in a front vrf, adapt the config to check the specific vrf)
Francesco
here is output
show ip bgp summary
BGP router identifier 72.29.230.181, local AS number 16569
BGP table version is 25827281, main routing table version 25827281
747509 network entries using 107641296 bytes of memory
1491087 path entries using 119286960 bytes of memory
232055/116395 BGP path/bestpath attribute entries using 35272360 bytes of memory
202832 BGP AS-PATH entries using 8603774 bytes of memory
1038 BGP community entries using 47350 bytes of memory
95 BGP extended community entries using 2556 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
103 BGP filter-list cache entries using 1648 bytes of memory
BGP using 270855944 total bytes of memory
722 received paths for inbound soft reconfiguration
BGP activity 1905580/1158047 prefixes, 5019660/3528573 paths, scan interval 60 s ecs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State /PfxRcd
72.29.230.182 4 25983 7054589 67060 25827252 0 0 3w0d 745 300
192.41.x.x 4 16569 3656685 6134122 25827281 0 0 3w0d 723 291
199.116.233.104 4 15296 248994 67057 25827252 0 0 3w0d 17 821
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
199.116.234.90 4 15296 90783 67053 25827252 0 0 3w0d 3951
show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is 72.29.230.182 to network 0.0.0.0
Based on your show ip bgp summary output, there are 4 peerings:
1 —> 72.29.230.182 4 25983 7054589 67060 25827252 0 0 3w0d 745 300
2 —> 192.41.x.x 4 16569 3656685 6134122 25827281 0 0 3w0d 723 291
3 —> 199.116.233.104 4 15296 248994 67057 25827252 0 0 3w0d 17 821
4 —> 199.116.234.90 4 15296 90783 67053 25827252 0 0 3w0d 3951
for peering 1 and 2, you’re receiving the full table. However with peer 3 and 4 you’re receiving some prefixes but not the full internet bgp table.
Your show ip route is empty which is weird because you should get something in.
Can you share the output of show run | s r b please?
Also rerun the show ip route to validate you have something in.
Francesco
1# show run | s r b
1#
we have routes in output of show ip route
they are all BGP and full routing table
Also if we lose link to ISP 1 72.29.230.182
we can learn routes from second ISP  192.x.x.x?
I don’t know if you have copy/paste issues but don’t see your router config.
Anyways, based on prefixes you’re learning, yes routes from 192.x.x.x ISPs should be installed in your RIB.
But if you didn’t managed which ISP must be prioritized, maybe you already have some prefixes from ISP2 already installed into your RIB. ISP 192.x.x.x has the same AS as your own router which means you’re running iBGP whereas ISP1 is in ebgp.
Francesco
here is output
show ip route
B* 0.0.0.0/0 [20/0] via 72.29.230.182, 3w0d
1.0.0.0/8 is variably subnetted, 2660 subnets, 14 masks
B 1.0.0.0/24 [200/0] via 192., 2w1d
B 1.0.4.0/22 [200/0] via 192.x.x.x, 3w0d
B 1.0.128.0/19 [200/1710] via 192.x.x.x, 3w0d
B 1.0.128.0/24 [200/0] via 192.x.x.x2w4d
B 1.0.129.0/24 [200/430] via 192.xxx, 3w0d
B 1.0.131.0/24 [200/0] via 192.x, 2w2d
Seems it is preferring IBGP route from 192.x.x.x?
any reason why it is doing that?
can you share output of:
sh ip bgp 1.0.131.0/24
Francesco
BGP routing table entry for 1.0.131.0/24, version 6538875
Paths: (2 available, best #2, table default)
Not advertised to any peer
Refresh Epoch 1
25983 6327 3491 38040 23969
72.29.230.182 from 72.29.230.182 (72.29.224.129)
Origin incomplete, localpref 100, valid, external
Community: 6327:2001 6327:30999
rx pathid: 0, tx pathid: 0
Refresh Epoch 1
192.x.x.x  from x.x.x.x  (64.141.118.154)
Origin incomplete, metric 0, localpref 100, valid, internal, best
rx pathid: 0, tx pathid: 0x0
We can see the prefixe learned from 72.29.230.182 has a longer as-path which is why it prefers the ibgp route.
Francesco
can you please tell me which config points to longer as-path?
BGP prefers path with shorest AS path as per my understanding
Yes BGP prefers a shortest AS-PATH that's why you see routes into your RIB pointing to 192.x.x.x ISP.
Refresh Epoch 1
Refresh Epoch 1
Based on your output you can see that learned prefix from 192.x.x.x has a shortest as-path.
Francesco
Hello
Just like to add I doubt very much you are receiving full bgp internet table from all peers after bgp has fully converged.
@mahesh18 wrote:
show ip bgp summary
72.29.230.182 4 25983 7054589 67060 25827252 0 0 3w0d 745300
192.41.x.x 4 16569 3656685 6134122 25827281 0 0 3w0d 723291
199.116.233.104 4 15296 248994 67057 25827252 0 0 3w0d 17821
Kind Regards
Paul
Just saw your note now  yes we are receiving full routing table from the ISP.
