ASR1001 BDI interface
Andrej Zverev
Hello.
I plan to connect the two ASA 5540 to the ASR 1001. ASA cluster operates in active\standby mode.
I'm correctly understand the documentation that such a scheme would work right when failover will occur?
ASR IOS XE Version: 03.06.01.S
interface GigabitEthernet0/0/1
description asa1
no ip address
negotiation auto
service instance 1 ethernet
  encapsulation untagged
  bridge-domain 1
interface GigabitEthernet0/0/2
description asa2
no ip address
negotiation auto
  bridge-domain 1
interface BDI1
ip address x.x.x.1 y.y.y.y
ip route 10.0.0.0 255.0.0.0 x.x.x.2 # as example route will work correct.
ASA interface has IP address x.x.x.2 standby x.x.x.3
Giuseppe Larosa
Hello Andrej,
it should work as the BDI feature is like IRB in IOS routers, but in this network setup the ASR 1001 is a single point of failure.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Andrej,
Hope to help
Giuseppe
Hello Giuseppe,
Thank you for confirmation of possibility. This was not complete design, in real there no point of failure actually.
