ASR1004 IOSd Memory allocation problem
macho.pellegrini
Community Member
Hello All,
As per Cisco documentation: https://goo.gl/wKDdBp
"The memory that is split between IOSd and the rest of the system is fixed at startup and cannot be modified. For a 4-GB system, IOSd is allocated approximately 2 GB, and for a 8-GB system, the IOSd is allocated approximately 4 GB (with software redundancy disabled)."
I have an ASR1004 with 8GB of RAM however the router only allocates 1.5G to the IOSd? And the SW redundancy is disabled!
cisco ASR1004 (RP2) processor (revision RP2) with 1486307K/6147K bytes of memory.
8388608K bytes of physical memory.
er2.blu.531.269#show running-config | sec redundancy
redundancy
 mode none
er2.blu.531.269#show platform software status control-processor brief
Load Average
 Slot  Status  1-Min  5-Min 15-Min
  RP0 Healthy   0.00   0.00   0.00
 ESP0 Healthy   0.00   0.00   0.00
 SIP0 Healthy   0.00   0.00   0.00
Memory (kB)
 Slot  Status    Total     Used (Pct)     Free (Pct) Committed (Pct)
  RP0 Healthy  8097480  4501624 (56%)  3595856 (44%)   3243328 (40%)
 ESP0 Healthy  8097460  1394608 (17%)  6702852 (83%)   1140776 (14%)
 SIP0 Healthy   969060   393352 (41%)   575708 (59%)    663936 (69%)
Mem:   8097480k total,  4501328k used,  3596152k free,   243248k buffers
Is it familiar to anybody here?
MP
macho.pellegrini
Community Member
Am I facing a corner case?
