Bandwidth on Ethernet
smallrain_2
Level 3
Level 3
I have a fast ethernet link to our ISP box. Our guranteed service is only 30Mbps.
What is the best way to configure our fast ethernet interface to limit traffic to 30Mbps?
5 Replies 5
Jon Marshall
You need to use shaping on your ethernet interface ie.
class-map match-all Class_Default
match any
policy-map WAN_Shape
class Class_Default
shape average 30000000
int fa0/1
service-policy output WAN_Shape
The ISP will probably police the traffic on their end but you are better off using shaping as it is a bit less drastic.
Jon
Joseph W. Doherty
Another option, your Ethernet interface might support GTS, e.g. "traffic-shape rate 30000000". However, I endorse Jon's suggestion of using CBWFQ for future QoS options.
PS:
BTW: class-default is an implict class, you shouldn't need to define a class-map for it.
"BTW: class-default is an implict class, you shouldn't need to define a class-map for it."
I know, i just thought it would be a better example rather than just a shape statement under the policy-map. Looking at it now you may have a point 🙂
Jon
It is a fine example, postscript was directed to other readers, such as perhaps OP, who might not have been aware of the fact.
Thanks all.
