Bandwidth Utilization Calculation
Can some one tell me how to calculate BW utilization from the router with input and output rate.
GigabitEthernet0/0 is up, line protocol is up
  Hardware is iGbE, address is 7081.050c.9e00 (bia 7081.050c.9e00)
  Description: *Gateway to VSNL-38Mb*
  Internet address is 10.70.10.202/30
  MTU 1500 bytes, BW 750000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 10/255, rxload 1/255
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 2w0d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 68599
  Queueing strategy: fifo
  Output queue: 0/2000 (size/max)
  30 second input rate 4784000 bits/sec, 2562 packets/sec
  30 second output rate 31248000 bits/sec, 3647 packets/sec
     1676866172 packets input, 830513729 bytes, 0 no buffer
     Received 148357 broadcasts (0 IP multicasts)
     0 watchdog, 148309 multicast, 0 pause input
5 Replies 5
John Blakley
I see 4.7Mb inbound and 31Mb outbound. Is that what you're wanting to know?
HTH, John *** Please rate all useful posts ***
Actually this ouptut is for one interface . On the whole taking both input and ouput how to calculate Bandwidth utilization.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
30 second input rate 4784000 bits/sec (100 Mbps), 2562 packets/sec = 4.78%
30 second output rate 31248000 bits/sec (100 Mbps), 3647 packets/sec = 32.25%
or perhaps
30 second input rate 4784000 bits/sec (38 Mbps), 2562 packets/sec = 12.59%
30 second output rate 31248000 bits/sec (38 Mbps), 3647 packets/sec = 82.23%
Do you want to see the "realtime" utilization or you just want a snapshot?  Fluke's got some tools which can give you a history of your bandwidth utilization based on SNMP.
What is the model of your router and what is your bandwidth?  I can see you have some output drops which probably means the remote end of this interface is rejecting Tx packets from the router interface and to the next hop.
Use MRTG or PRTG software to moniter the link
