BFD on MPLS traffic engineering tunnel
pramod
How to configure BFD on tunnel interface (MPLS traffic engineering tunnel) for XR and IOS devices ? Please help....
Nagendra Kumar Nainar
Pramod,
If your requirement is to use BFD for FRR, you dont need to enable BFD on tunnel interface.
You need to configure "ip rsvp signalling hello bfd" command to enable BFD for MPLS TE FRR.
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_te_bfd_frr_ps6922_TSD_Products_Configuration_Guide_Chapter.html
If you have a different requirement, let us know.
HTHT,
Nagendra
here is the output for bfd neighbors
Router#sh bfd neighbors
OurAddr NeighAddr LD/RD RH/RS Holddown(mult) State Int
150.1.1.2 150.1.1.1 1/2 Up 0 (3 ) Up PO6/0
Router#
from above output instead on POS6/0 i need tunnel interface ! Is it possible
similary
XR device also
RP/0/4/CPU0:ios#show bfd session
Interface Dest Addr Local det time(int*mult) State
Echo Async
PO0/0/0/2 150.1.1.2 150ms(50ms*3) 6s(2s*3) UP
RP/0/4/CPU0:ios#
instead of pos0/0/0/2 i need tunnel-te!
