BGP AS-Prepend Limit?
ssieger
Level 3
Level 3
ist this a normal behaviour or is it possible to override this limitation of 10 prepends:
BGP-Router(config-route-map)#set as-path prepend XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX
% Cannot have more than 10 as-paths prepended
 My router is a 7206VXR (NPE-G2) IOS c7200p-spservicesk9-mz.122-33.SRE14
Thanks in advance,
Stephan
Philip D'Ath
Meraki Community All-Star
I just tested this on a modern platform with considerably newer software and got the same issue.
So yes, it seems normal that you are limited to 10 as-path prepends.
Thanks for that comparison Philip. May be that is the right to exist for the command "bgp maxas-limit"  🙂
