BGP Between Nexus and IOS Stack
benolyndav
Level 8
Level 8
Please see attached, the x2 Nexus 5k Switches are configured has a VPC pair already VPC domain 10
I want to configure ibgp between the Nexus Switches and the IOS Sack, the IOS Stack is runing EBGP peering with ISP Router,
we have subnets Southbound of Nexus which I would like to advertise to the IOS Stack using IBGP
Ive been scratching my head with this lab and cant think of the best way to do this, ??? any help appreciated..
Hello
The main thing to reiterate would be that the if you were to do this then the igbp connections into the cisco stack would need to be two separate physical routed interfaces and not within a vpc as running a layer 3 over the vpc wouldn’t be an appropriate design choice due to the vpc L2 functionality.
Kind Regards
Paul
6 Replies 6
Richard Burts
I am a bit confused about this question. If there are networks southbound of the Nexus switches I would think that some Interior routing protocol (OSPF, EIGRP, etc) would be a better choice of how to advertise them. Why would you want to use IBGP for this?
Rick
Its a requirment for a new SDN project where we have to run BGP between nexus and the Stack.
 - I am confused about that too , note that nexus is data-center oriented, in that context I would advise static knowledge-based routes to the "dmz-perimeter-isp".  Preferably with a firewall in between , or stated otherwise. 'Don't terminate BGP on the nexus'
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
HI
The IOS Stack where we peer using EBGP with ISP is a private wan(vrf) the IBGP is just to advertise new subnets into BGP and move away from statice routing,
Hello
Kind Regards
Paul
pman
  • IBGP between SW1 and STACK interfaces can be L3/SVI, if SVI so this VLAN is local to SW1-STACK only
  • IBGP between SW2 and STACK interfaces can be L3/SVI, if SVI so this VLAN is local to SW2-STACK only
  • IBGP between SW1 and SW2 interfaces can be L3/SVI, if SVI so this VLAN is local to SW1-SW2 only
  • Regarding the question of whether to establish the IBGP between SW1 and SW2 over the peer-link or a dedicated interface - depending on Nexus type and version https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/118997-technote-nexus-00.html
