BGP - Conditional Default Origination
Joseph Nelson
Level 5
Level 5
We have a setup like the following:
e1------e2
c1        c2
The scenario has the following features:
  • iBGP full mesh between router loopbacks
  • Collapsed core/distribution design
  • Edge routers (e1, and e2) are dual multi-homed with 3 providers ( 2 providers are on e1 and another 1 provider is on e2). Both receive full+default announcements from the providers
  • Edge routers are advertising only a default route to the core routers (c1 and c2)
Goal:
  • Edge routers originate a default to core routers ( c1 and c2) if and only if they have a default route in their routing table
From the reading this "conditional announcement" can be achieved using the "neighbor x.x.x.x default-originate route-map rmap" command in router config mode. If at least one prefix in the route-map ( here: rmap) is matched in the local routing table, a default will be originated.
My question:
Can you specify the route-map to match on the default prefix as follows?:
config t
ip prefix-list IPV4-DEFAULT 10 permit 0.0.0.0/0
route-map IPV4-COND-DEFAULT seq 10 permit
match ip address IPV4-DEFAULT
end
config t
router bgp ASNX
neighbor x.x.x.x default-originate route-map IPV4-COND-DEFAULT
end
Reference:
http://www.cisco.com/en/US/docs/ios/iproute_bgp/command/reference/irg_bgp3.html#wp1105838
http://njetwork.wordpress.com/2013/01/28/bored-with-bgp-generating-a-default-route/
http://blog.ipspace.net/2011/09/responsible-generation-of-bgp-default.html
Hi Joe,
Don't recall if I have any customer is doing it; just tested it in lab
R1#sh run | sec router bgp
router bgp 100
bgp log-neighbor-changes
neighbor 10.10.10.2 remote-as 200
neighbor 10.10.10.2 default-originate route-map DEFAULT
R1#sh route-map
route-map DEFAULT, permit, sequence 10
  Match clauses:
    ip address prefix-lists: DEFAULT
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
R1#sh ip prefix-list
ip prefix-list DEFAULT: 1 entries
   seq 5 permit 0.0.0.0/0
R1#sh ip route
S*    0.0.0.0/0 is directly connected, FastEthernet0/1
      10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C        10.10.10.0/24 is directly connected, FastEthernet0/0
L        10.10.10.1/32 is directly connected, FastEthernet0/0
C        10.10.20.0/24 is directly connected, FastEthernet0/1
L        10.10.20.1/32 is directly connected, FastEthernet0/1
R2#sh ip route
B*    0.0.0.0/0 [20/0] via 10.10.10.1, 00:00:47
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
L        10.10.10.2/32 is directly connected, FastEthernet0/0
remove static default from R1
R1#sh ip route
R2#sh ip route
HTH,
Lei Tian
Lei Tian
Yes, that config looks right.
HTH,
Lei Tian
Lie,
Thanks for your reply. Have you every configured something like this? What was your experience configuration a conditional default in this way?
Other feedback welcomed.
Joe
Hi Joe,
router bgp 100
R1#sh route-map
  Match clauses:
  Set clauses:
R1#sh ip route
R2#sh ip route
R1#sh ip route
R2#sh ip route
HTH,
Lei Tian
Excelent Lei!
Thanks I had some doubts but you've solidified it for me. Thanks again.
Joe
