BGP-confederation best path selection
m.taras_u
Hi, dear community!
Can someone help me to resolve question about best path selection in BGP-confederation. I have:
BGP routing table entry for 4.0.0.0/24, version 42
Paths: (4 available, best #2, table Default-IP-Routing-Table)
  Advertised to peer-groups:
     1001
  Advertised to non peer-group peers:
  1.1.3.2
  (65504) 204, (received & used)
    1.1.4.1 (metric 20) from 1.1.4.1 (192.168.1.5)
      Origin incomplete, metric 50, localpref 100, valid, confed-external
      Community: 1001:1001
  (65501 65504) 204, (received & used)
    1.1.1.1 (metric 20) from 1.1.1.1 (192.168.1.1)
      Origin incomplete, metric 50, localpref 100, valid, confed-external, best
  (65502 65501 65504) 204, (received & used)
    1.1.2.1 (metric 20) from 1.1.2.1 (192.168.1.3)
    56.1.2.90 (metric 20) from 1.1.3.2 (192.168.1.8)
      Origin incomplete, metric 50, localpref 100, valid, confed-internal
And I can't figure out why best path is selectin not according to as-path, but to router-id...
Could someone help me?:)
Thanks!
Giuseppe Larosa
Hello Taras,
the confederation mini AS portion of the path is ignored. More specifically:
>>The AS_CONFED_SEQUENCE and AS_CONFED_SET are not included in the             AS_PATH length.
see
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml#background
The reason is that the mini AS in confederation are kept in a separate field/attribute named
AS_CONFED_SEQUENCE (that describes the paths within the BGP confederation only),
  in order to be easily stripped toward a true eBGP neighbor that sees the public AS number as the peer-as.
Hope to help
Giuseppe
