BGP default community
nikhil.kulkarni
Level 3
Level 3
All,
What is the default community value that is injected in a iBGP neighborship?
As an example, I have routers A and B in iBGP
Router B just has a statement"
neighbor "IP of A" send-community
What will this statement really do? what kind of community will this send? no-export?
Nik
cadet alain
if you don't set the community it will send none, what does this command is simply tell the router no to strip the community values  if there are some  when sending updates.
Regards.
Alain
