BGP - Inject Default Route
jason crockett
Our network is running MPLS using BGP at several remote sites. Some of these remote sites do not have a separate internet connection so their internet traffic is backhauled to our data center on the east coast. We are opening an additional data center near the west coast and would like to backhaul internet traffic at our remote offices on the west coast to this new data center. But right now I am trying to understand how our internet traffic is currently being backhauled to the east coast data center. I understand how this traffic leaves the remote site MPLS router but what I do not understand is how it terminates at our data center MPLS router. I know one way of doing this is to add the neighbor x.x.x.x default-originate command to the data center MPLS so that it sends the default route 0.0.0.0 to it's neighbor. But I do not see this command in the BGP configuration on the data center MPLS router. How else can this be done?
Here is the BGP configuration on the data center MPLS router.
router bgp 12345
bgp log-neighbor-changes
neighbor D3 peer-group
neighbor D3 remote-as 5678
neighbor D3 soft-reconfiguration inbound
neighbor D3 route-map D3-IN in
neighbor 10.64.99.1 remote-as 12345
neighbor 10.64.99.1 next-hop-self
neighbor 10.64.99.1 soft-reconfiguration inbound
neighbor 10.64.99.16 remote-as 12345
neighbor 10.64.99.16 next-hop-self
neighbor 10.64.99.16 soft-reconfiguration inbound
neighbor 69.269.68.169 peer-group D3
jason crockett
Here is some more info that may be helpful.
Remote office router BGP configuration
We have dual MPLS providers at this site. Both terminate in the same 2911 router.
router bgp 12345
no synchronization
network 10.50.1.15 mask 255.255.255.255
network 10.50.15.0 mask 255.255.255.0
network 10.50.115.0 mask 255.255.255.0
network 172.16.15.0 mask 255.255.255.0
network 172.16.115.0 mask 255.255.255.0
neighbor D3 route-map D3-OUT out
neighbor MA peer-group
neighbor MA remote-as 19855
neighbor MA soft-reconfiguration inbound
neighbor MA route-map MA-IN in
neighbor MA route-map MA-OUT out
neighbor 10.2.0.41 peer-group MA
neighbor 62.15.21.190 peer-group L3
no auto-summary
Peter Paluch
Your BGP is currently not configured to inject a default route. Do you see it in your routing tables on any router, learned by BGP? If yes then it may be injected there by your ISP instead of your own BGP routers. You could enter the
show ip bgp 0.0.0.0
to see who advertises this network. Ideally, if you have access to some of your locations that use the backhaul to transport internet traffic to your data center, you should inspect their routing tables carefully, as the answer must already lie there - if the internet is working, the routing tables must already be set up properly.
One comment: you are using the neighbor X.X.X.X soft-reconfiguration inbound commands in your BGP configuration. This command was used years and years ago to permit your router to store the complete unfiltered database of all routes the neighbor X.X.X.X sent to you. This allowed your router to apply new inbound policies without dropping the BGP peering and retransmitting the prefixes again. It was a naive workaround around the former BGP limitation in which you could not ask your neighbor to resend you its BGP database. The obvious drawback is an increased memory footprint. Since RFC 2918 which dates back to September 2000, however, the BGP is extended with a native capability to request the neighbor to resend all routes of a particular address family (the so-called ROUTE REFRESH), and hence, this soft-reconfiguration inbound is obsolete. You should remove these configuration lines as you do not need them, and they make your router only to consume more memory.
Best regards,
Peter
Thanks for the response. I definitely do not see BGP configured to inject a route. That is why I wasn't sure how the remote sites know to send internet traffic to the data center MPLS router. Perhaps it is injected by the ISP. I will reach out to them.
Here is the show ip bgp 0.0.0.0 command run from the remote office router. It's using the 3rd path because we manipulated the weight to 3000.
Remote Office Router#show ip bgp 0.0.0.0
BGP routing table entry for 0.0.0.0/0, version 89405
Paths: (4 available, best #3, table default)
  Not advertised to any peer
  19855 19855
    10.2.0.41 from 10.2.0.41 (64.47.0.79)
      Origin IGP, localpref 100, valid, external
      Extended Community: RT:19855:88088226
  19855, (received-only)
  5678 5678
    62.15.21.189 from 62.15.21.189 (206.165.188.153)
      Origin IGP, localpref 100, weight 3000, valid, external, best
  5678 5678, (received-only)
