BGP multipath limit
zdmr
Visitor
Hi there,
I see a statement in the following document on page 2: "The valid values for the maximum-paths command range from 1 to 32. However, the maximum value that can be configured is 2."
Document link: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/17-1/configuration_guide/mpls/b_171_mpls_9500_cg/configuring_eibgp___multipath.pdf
What does it mean? How many paths (ISPs) can eBGP use at the same time — 2 or more? Do not consider device, MPLS-VPN etc.
Thanks in advance.
The multipath option is just as you suspect but can be applied to both eBGP or iBGP. The limitation is platform specific. The essence of multipath is that it allows you to perform load-balancing utilizing CEF. The standard behavior is to only install the BEST route. This feature allows you to override that and install a second route for load-balancing purposes.
HTH!
Ios xe is run on
C9000 series
Asr 1k
So max path can config from 1 to 32
For this particular platform c9500 the max path is 2.
So it platform limitations
MHM
M02@rt37
Hello @zdmr
The statement in the document refers to the configuration constraints for the maximum-paths command in the context of eBGP multipath on Catalyst 9500 switches.
The maximum-paths command supports values ranging from 1 to 32, meaning you can theoretically configure eBGP to load-balance traffic across up to 32 paths. The document states that only 2 paths can actually be utilized at the same time for eBGP multipath load balancing on these devices. This is a hardware or platform limitation, restricting eBGP multipath to a maximum of 2 paths regardless of the broader range allowed by the command syntax.
How Many ISPs Can eBGP Use Simultaneously? For a C9500 switch, the eBGP multipath feature allows load balancing across only 2 ISPs (or 2 eBGP paths) at the same time.
Best regards
