BGP re design
I currently need to re design our ISP connection into out core and WAN devices.
At the moment we have
1. 2 sites with 2 ISP devices connected to 2 separate Data Centres
2. 80 Wan devices
3. ISP Devices run BGP VRF and are connected into ISP cloud
4  The current set up on the ISP has had numerous Ad-hoc changes and it would be a nightmare to track down these routes as a number of them are in VPN's to devices/organization world wide
I have to remove the current 3750 ISP devices and replace them.
My issue is where do I start regarding the BGP re design
Seb Rupik
Hi there,
What problems are you experiencing with the existing design?
Are you adding any new links to the topology?
Can you share a topology diagram?
cheers,
Seb.
