BGP WEBSERVER PUBLISHING
Sihanu N
I wanted to publish a webserver without using nat.
With bgp I publish full network.. network 103.10.168.0
If I put one of the ip from the pool to webserver it avialable from internet???
103.10.168.4
255.255.255.0
103.10.168.1
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 117.239.74.241 255.255.255.252
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 103.10.168.1 255.255.255.0
duplex auto
speed auto
router bgp 131787
bgp log-neighbor-changes
neighbor 117.239.74.242 remote-as 9829
neighbor 117.239.74.242 version 4
address-family ipv4
  network 103.10.168.0 mask 255.255.255.0
  neighbor 117.239.74.242 activate
exit-address-family
show ip bgp summ
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
117.239.74.242  4         9829       4       5        3    0    0 00:00:33        1
thanks
Sihanu N
ahmad82pkn
Level 3
Level 3
You dont need NAT if you are assigning public IP directly to Server.
All you need is routing available.
by the on which interface your bandwidht is connected on this router?
Giuseppe Larosa
Hello Sihanu,
yes without NAT, If there is OSI layer2 connectivity between the web server NIC and  router gi0/1 interface for example with a LAN switch in the middle
note: your prefix is on the internet so eBGP is fine.
Hope to help
Giuseppe
