BGP
sudhir.tyagi
I need to configure the BGP on cisco 1841 router with two MPLS lines running on WAN interface and LAN interface.
Has anyone an example configuration I can use as a guide?
Hello
You bgp peering would be seamless - You wont need to know about the mpls part as your isp deals with that>
Are your two wan connections from two different isp's from one router?
I assume you want to prefer a primary and secondary path?
And have your lan resilient to an outage of either ISP?
res
Paul
Kind Regards
Paul
Nikhil Kapoor
Hi Sudhir,
If I understand your question correctly. I guess you want to configure CE with in MPLS VPN scenario. If that is the case you may want to look at below links.
http://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/13733-mpls-vpn-basic.html
http://www.cisco.com/c/en/us/td/docs/ios/mpls/configuration/guide/12_2sy/mp_12_2sy_book/mp_cfg_layer3_vpn.html#wp1062232
HTH,
Nikhil
thanks Nikhil.
Hello
res
Paul
Kind Regards
Paul
sudhir.tyagi
yes.
