Block External SSH and Login Without aaa
Zygodactyl
So I can't seem to figure out how to do this.
On an perimeter router I just want to block any incoming SSH traffic to the router except from three internal subnets. Then i also want to authenticate with a local account and not leverage aaa. so the result is not one can directly externally connect to the router via SSH but i can still SSH into our router internally using local accounts.
it seems that i can't selectively block SSH traffic without aaa and I can't login with local account with aaa.
This seems to me that this should be very simple to configure.
Current configuration : 5161 bytes
! Last configuration change at 21:52:47 UTC Wed Jul 24 2019 by <redact>
version 15.5
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname ISR4431
boot-start-marker
boot system bootflash:/isr4400-universalk9.03.16.05.S.155-3.S5-ext.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 <redact>
aaa new-model
aaa session-id common
ip vrf Internet
 rd 2:2
ip vrf MPLS
 rd 1:1
ip domain name <redact>
subscriber templating
license udi pid ISR4431/K9 sn <redact>
license boot level securityk9
username <redact> access-class 15 secret 8 <redact>
redundancy
 mode none
interface GigabitEthernet0/0/0
 description LAN-VRF-MPLS
 ip vrf forwarding MPLS
 ip address 10.92.1.254 255.255.255.0
 negotiation auto
interface GigabitEthernet0/0/1
 description LAN-VRF-Internet
 ip vrf forwarding Internet
 ip address <redact>
 negotiation auto
interface GigabitEthernet0/0/2
 description WAN-VRF-MPLS
 ip address <redact> <redact>
 negotiation auto
interface GigabitEthernet0/0/3
 description WAN-VRF-Internet
 ip address <redact>
 negotiation auto
 vrf forwarding Mgmt-intf
 ip address <redact>
 negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/0
ip ssh version 2
ip access-list standard Limit_SSH
 permit 10.92.1.0 0.0.0.255
 permit 10.91.3.0 0.0.0.255
 permit 192.168.1.0 0.0.0.255
 deny   any
access-list 1 permit 10.92.1.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 101 deny   udp any eq 22 any
access-list 101 deny   tcp any eq 22 any
access-list 101 permit ip any any
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 access-class Limit_SSH out
 transport input ssh
 transport output ssh
line vty 5 15
 access-class Limit_SSH in
 transport input ssh
figured it out....
This router is using vrf's and when you are using vrf's you need to add vrf-also to the vty lines or else it will not route correctly.
access-class Limit_SSH in vrf-also
8 Replies 8
if you don't want to use aaa, you need to configure 'login local' on the lines and define local user acounts:
username admin privilege 15 password 0 cisco
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
Seb Rupik
Hi there,
@Georg Pauwen answer is correct, but if you did want to use AAA, then you simply need to create a AAA method which uses the local user store only:
username foo priv 15 secret bar
aaa authentication login LOCAL_ONLY local
line vty 0 4
login authentication LOCAL_ONLY
cheers,
Seb.
Weird so i removed aaa and i can't ssh from 192.168.1.0/24 i get a connection refused
wtf am i missing, the hops from endpoint to that router are 192.168.1.148 > 192.168.1.100 another router > 10.92.1.254 the ISR
Do i need to remove the SSH in policy or something?
wow this is infuriating...
i have made the most basic vty config i can think of. and the second i add a
access-list
via the
access-class
command i get a connection refused
line con 0
 login local
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login local
 transport input ssh
 transport output none
line vty 5 15
 login local
 transport input ssh
here is the
access-list
which should have a implied deny all at the end.
and i am adding the following line to the vty lines when it fails
access-class 1 in
also forgot to mention i tried both listed methods and it did not work.
figured it out....
Thanks for the update. Glad to know that you found the solution to your problem. We should have noticed the vrf use.
Rick
Rick
The original post had
access-class
applied out but not in for vty 0 4 and that was a problem that would have allowed incoming SSH. But I am not clear why the more recent config which uses a number standard
access list
and applies it "in" is not working. Are you sure that your SSH request has its source address as either 10.92.1.0/24 or 192.168.1.0/24?
Just to be sure that I am understanding the situation correctly, in the current config without configuring
access-class 1
in then SSH is successful. But when you configure
access-class 1
in on the vty then SSH fails?
Rick
Rick
