11-06-2008 11:58 AM - edited 03-04-2019 12:13 AM
Hello..
Trunk OF card BXM-622 OC-12 dont pass through of data.
Detail: Stats trunk is Active
BPCTIA01 VT Service BPX 8620 9.2.43 Nov. 6 2008 17:56 G-03
TRK Type Current Line Alarm Status Other End
1.1 OC12 Clear - OK BPCTIB01/1.1
9.1 OC12 Clear - OK BPCTIB01/9.1
11-12-2008 02:18 PM
If it seems to the problem on trunk. Try to reset this trunk at both ends. Else I think the issue here is the longer route seems to be the best route from the BPX perspective coz when a preferred route is configured on the shorter route, it works
pretty well but when a connection is created normally, the network chooses the longer route to build it. Maybe the Routing algorithm is mixed up here....
11-12-2008 03:05 PM
Hello...
Interconnected via card OC-12 in both.
I have some interfaces OC-3 interconnected in such a way, however OC12- not.
you know some difference between configuration of CARDs OC12 for OC-3 ?
this can be the problem !!
my team it knows very of Cards OC3, however OC12- not.
thanks !!
