Bridging 877
mark.mclaughlin
Community Member
I have... 2 public IP 's.
an adsl modem -> 877 -> a managed vpn appliance connected via eth.
I have given the atm0 one of the addresses and the vpn appliance the other.
I tried to set up pure bridging following..
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a816.shtml
and am running into problems. When I get to the point of assigning the bridge-group to the f0, I get an error message..
fastethernet0 does not support bridging.
I then assigned vlan1 to the bridge-group successfully. Seems OK to me, but the 877, and the connected vpn appliance cannot ping each other in either direction.
any ideas appreciated.
Giuseppe Larosa
Hello Mark,
the fas ports are seen as switch ports you need to declare association to bridge-group 1 under int vlan 1
int vlan1
no ip address
bridge-group 1
being fas0 in vlan 1 with default config you achieve the desired result
see bridging over vlans
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html#wp999748
Edit:
I see you have already discovered this however follow the document you may be missing some global config command about irb or crb.
Hope to help
Giuseppe
I realize this was a super long time ago, but I've been struggling with this one as well.  Thanks Giuseppe!  Worked instantaneously.
I guess I just figured that the sub interface would tie them together...but that wasn't enough.  I had to have a interface vlan <#> then add that to the bridge group.
