Bstun
lovefunlove
Level 2
Level 2
Hello Guys,
I working in a scenario for Bstun configuration.Have done all the configuration according to the cisco documents regarding Bstun, but still its not working.
Please go through the attached file and give your expert comments.
MAX
5 Replies 5
does the hdlc interface come up on both 2651-A and 2651-B?
Have you tried:
bstun route all tcp <10.20.20.20>
and
bstun route all tcp <10.10.10.10>
instead of
bstun route all tcp int serial 1
and
Hope this helps,
Hello Hritter,
Thanks for your reply.
I have tried bstun route all tcp <10.20.20.20>
and
In both the cases ,But with this route the tunnel is not comming up.when i am connecting the two 1721 routers either with ethernet or Serial.
MAX
Did you try doing an extended ping between the two routers loopback adddresses. It could have been a connectivity issue.
Hope this helps,
Hi Hritter,
yes i am able to picg the loopback addresses of 1721 from each other.
In 2651 the HDLC line protocol and all the 4 line signals are also up.But i am not been able to ping 1721.
When i a am connecting the 2 1721 with serial interface then only the tunnel is comming up and also only by giving "Bstun route all int serial 1" and not my " Bstun route all tcp IP Address"
When the tunnel is up with serial connectivity but till i am not been able to ping the 2651-A to 2651-B
Please suggest what might be the issue.
Waiting for your reply.
MAX
Sorry I can't help you further. I would suggest you post this issue on the "Enterprise Data Center Networking" under Network Infrastructure. This is where you get the real experts for BSTUN.
Hope this helps,
