C1300
Hello All,
I have a question: Does the C1300-16XTS support the PIM protocol? And do the interfaces also support 1G SFP modules?
Thanks!
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-1300-series-switches/nb-06-cat1300-ser-data-sheet-cte-en.html
             >...The 10 Gigabit copper and SFP+ ports support 10 Gigabit and 1 Gigabit speeds.
    Browsing this document : https://www.cisco.com/c/en/us/td/docs/switches/campus-lan-switches-access/Catalyst-1200-and-1300-Switches/cli/C1300-cli.pdf
        It looks like PIM is supported
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Aleksandra Dargiel
nope PIM is not supported on C1300 or C1200 series
