c3750/x ssh automatic login
steven.geerts
Community Member
does anybody know if it's possible to automatically login via ssh to a c3750.
I use this a lot with other servers and I fill in my public rsa key on the server to automatically login their.  But I'm not able to do this with the cisco.
If somebody has an idea on how to do this?
blau grana
Level 11
Level 11
It is possible. I connect to cisco 2911 using PKI from linux box.
Theese are steps which I was following:
http://www.m00nie.com/2010/12/password-less-ssh-login-using-pki-to-cisco-ios/
But before that check your IOS version if it supports this feature.
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 11
Level 11
