c8300
Robert Plunkett
Level 2
Level 2
How do I turn on the feature that let me configure "isakmp" so I can configure a cypto profile. I have tried everything that google has to offer, and nothing works.
I thank everyone for their input, I think the solution was, I was using the NPE version of the IOS once I changed to the none NPE I was able to issue all the commands.
18 Replies 18
M02@rt37
Hello @Robert Plunkett
Which license have you got ?
Please do that command
boot level Network-Advantage addon dna-advantage
Save and Reboot the C8300.
That should enable ipsec.
Best regards
The license I have is 17.14.01a.
That did not work for me.
Hello
you need to enable it within the licencing, save changes and reload rtr, then you should have the crypto options available .
conf t
license boot level network-advantage addon dna-advantage
do wr mem
reload
Kind Regards
Paul
When I contacted cisco TAC they said the license subscription we have is plug-n-play, how, do I enable it?
What is relate of isakmp and ipsec profile
What you try here ?
MHM
Good morning,
I am trying to create a crypto policy to be attach to a tunnel, however, when I type "crypto" no entry is availble for "isakmp".
Are router accept crypto map?
MHM
Hello
Have you tried running that command I suggested?
Kind Regards
Paul
Yes, I have tried, and I have tried all that google had to offer.
Hello
then it sounds like your licencing isnt correct. probably you have network essentials ( like the old ipbase ) which isnt applicable for crypto.ipsec etc...
Kind Regards
Paul
Does that mean I should download a different version of the ios?
Hello
no you'll probably need to obtain a network advantage licence
can post the output of the following please off your rtr:
sh version | in Soft|Lic
Kind Regards
Paul
