C9200 Switch automatic interface shutdown when other interface is down
xzevallos
I would like to know if it is possible to configure a C9200 switch to automatically shutdown an interface if it detects another interface going down.
xzevallos
Thanks all for your answers, I will try the EEM method.
Sure there is way
Use EEM
Event pattern log interface down
Acrion interface x/x shutdown
MHM
@xzevallos
 If you search you are going to find the exactly script you need but you can also use one as reference, in case you dont find exactly.
https://sites.google.com/site/amitsciscozone/network-management/changing-interface-state-using-eem
Leo Laohoo
Shutting it down is not a good idea but changing the VLAN to an "isolation" VLAN is the best method.
xzevallos
