Cabling 2960x Stack
Azuriste
I have 3 2960x switches and i wanna prepare a stack.
in each switch i have two ports stack : Stack1 & Stack2
Could you tell me how to cable these switches please ?
i make Switch1 Stack1 to Switch 3 Stack2
and Switch1 stack2 to Switch 2 stack1
and switch2 stack2 to Switch 3 stack 1
and its nit working
Hello
1) provision your stack switchs from the switch that you wish to be the stack master whilst the stack creation takes place
Example
switch 2 provision ws2960x-24ts
switch 3 provision ws2960x-24ts
2)cable the switchs as such their stack cables are like
sw1 port 1 — sw port2
sw2 port 1 - sw3 port 2
Sw3 port 1 - sw1 port 2
Make sure the switchs are powered down before you attach the stack cabling then power them up
laslty once the stack is up you can change the switch priorities to accommodate which switch you prefer to be the master
(this can be done before the stack is brought up but if need be)
Kind Regards
Paul
pieterh
basically you connect a stack-1 port to a stack-2 port
with three switches you have
sw1-st1 -> sw2-st2
sw2-st1 -> sw3-st2
and to close the loop
sw3-st1 to sw1-st2
Hello
Example
Kind Regards
Paul
Thanks .I didnt make a Provision command .is it mandatory ?
