Can’t ping the internet from router
Phil007
I have Cisco 881 with SIM card and I cam not able to ping the internet. Could you please advise?
My config is below, it is full of garbage because I have already tried to find a solution... :(
Current configuration : 3131 bytes
! Last configuration change at 10:17:50 UTC Wed Feb 28 2018
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool testpool
network 192.168.1.0 255.255.255.0
ip dhcp pool A
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
dns-server 8.8.8.8 8.8.4.4
lease 9
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
chat-script CellScript "" "AT!CALL" TIMEOUT 60 "OK"
chat-script cdma "" "ATDT#777" TIMEOUT 60 "CONNECT"
license udi pid C881G-4G-GA-K9 sn FCZ2147E2DH
username admin privilege 15 password 0 admin
redundancy
controller Cellular 0
lte sim data-profile 1 attach-profile 1 slot 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface Loopback0
ip address 192.168.1.1 255.255.255.255
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer string cdma
dialer string gsm
dialer watch-group 1
dialer-group 1
async mode interactive
interface Cellular1
no ip address
encapsulation slip
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Dialer2
encapsulation ppp
dialer pool 2
dialer string CellScript
dialer persistent
dialer-group 2
ppp authentication pap callin
ppp ipcp dns request
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool test 4.4.4.4 4.4.4.4 netmask 255.255.255.0
ip route 0.0.0.0 0.0.0.0 Dialer2
ip route 0.0.0.0 0.0.0.0 Cellular0
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
dialer watch-list 1 ip 5.6.7.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
dialer-list 1 protocol ip list 1
dialer-list 2 protocol ip permit
ipv6 ioam timestamp
access-list 1 permit any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
vstack
line con 0
exec-timeout 0 0
script dialer cdma
login
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
stopbits 1
line 3
script dialer CellScript
no exec
speed 384000
line 8
no exec
speed 384000
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
Yes, you need to evaluate how will be your primary and second path, if you are going to use dialer 2 first and cellular0 as backup the configuration should be:
ip route 0.0.0.0 0.0.0.0 dialer2 name PRIMARY-ISP
ip route 0.0.0.0 0.0.0.0 cellular0 20 name SECONDARY-ISP
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
18 Replies 18
Julio E. Moisa
At simple sight the following is missed:
Ip nat inside ; it should be used for the private networks to be translated
ip nat inside source list <ACL> pool <Pool name> overload
The pool test is not valid, the addressing 4.4.4.4 is already taken. The ISP should provide you the IP addresses to be considered as Public IP addresses / Outside global IP addresses.
Now you have 2 default routes, you could include an administrative distance higher to one of them to be the backup, have you tried making ping to 8.8.8.8 (Google DNS) from this device?
Hi Julio,
and which interface should have set ip nat inside? Vlan1, right?
I am also not sure how to set up ACL...
it should be like: ?
ip nat inside source list ACL1 pool A overload
Hi Phil
The ip nat inside is configured under the interface pointing or associated to your internal networks or corporate networks. Now the ip nat outside is configured under the exit interface in the most of the cases it is configured under the interface facing to the ISP or Internet.
Now an example could be:
Router
Int g0/0
description ISP-INTERNET
ip add 190.190.190.5 255.255.255.248
ip nat outside
no shutdown
Int g0/1
description MY-LAN1
ip add 172.16.10.1 255.255.255.0
ip nat inside
no shutdown
Int g0/2
description MY-LAN2
ip add 172.17.25.1 255.255.255.0
ip nat inside
no shutdown
ip access-list standard MY-PRIVATE-NETWORKS
permit 172.16.10.0 0.0.0.255
permit 172.17.25.0 0.0.0.255
ip nat inside source list MY-PRIVATE-NETWORKS interface g0/0 overload
ip route 0.0.0.0 0.0.0.0 g0/0
or
ip route 0.0.0.0 0.0.0.0 190.190.190.5  ; Assuming it is configured on the ISP side or it is the gateway of the network 190.190.190.0/29
It is just an example but can be adjusted to your configuration.
let me do what you advised and I will reply, thank you :)
You are welcome Phil, if you don't know your public IPs you could try with:
ip nat inside source list MY-PRIVATE-NETWORKS interface dialer2 overload
or
ip nat inside source list MY-PRIVATE-NETWORKS interface cellular0 overload
if you want to test you could configure the loopback0 with ip nat inside and include the IP into the ACL, then you can execute:
ping 8.8.8.8 source loopback0
It should work
Hi Julio,
I included ACL, however now I am able to ping via loopback and not via cellular if.
ping 8.8.8.8 source loopback0 - IS OK
ping 8.8.8.8 source cellular 0  - IS NOT WORKING
Could you please share your configuration? The trouble with the cellular0 could be because it is going through its own ISP and the default route is pointing to the Dialer2. We should verify the path from both souces in order to know the prefer path.
Thank you in advance
Here it is,
I just swap my public IP with 1.2.3.4
Building configuration...
Current configuration : 3416 bytes
! Last configuration change at 16:18:10 UTC Wed Feb 28 2018
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool A
lease 9
ip cef
no ipv6 cef
redundancy
interface Loopback0
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer string cdma
dialer string gsm
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
no ip address
description LAN
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Dialer2
encapsulation ppp
dialer pool 2
dialer persistent
dialer-group 2
no cdp enable
no ip http server
ip nat pool test 1.2.3.4 1.2.3.4 netmask 255.255.255.0
ip nat inside source list AA interface Cellular0 overload
ip access-list standard AA
permit 0.0.0.0
permit 192.168.1.1
permit 172.24.11.41
ipv6 ioam timestamp
control-plane
vstack
line con 0
exec-timeout 0 0
script dialer cdma
login
no modem enable
line aux 0
line 2
no exec
stopbits 1
line 3
no exec
speed 384000
line 8
no exec
speed 384000
line vty 0 4
login
end
Thank you, Try again but first shutting down the Dialer2 interface.
Wow! I did it and I am able to ping 8.8.8.8 via cellular 0 interface!
Thank you very much what was the issue, please?
OK, thank you.
I will erase my config now and "start from the bottom" again :)
I will let you know the results.
Thank you
Great, thank you Phil
It works!!!!
Thank you very much! So the only one issue was bad route...!
Thank you so much once more!!!
