Can't reach to web server via public IP when in same LAN as Web server
tariqfaizan
Hi There,
I have configured the router to enable public access to remote desktop server and web server (which is same server for both uses) but different port numbers. Now situation  is, this server is accessible from outside LAN via public IP but when within LAN it is not accessible.
When I do: show ip translation
I get results for the same as follows
Pro Inside global               Inside local                 Outside local         Outside global
tcp XXX.XX.XXX.XX:8101   XXX.XX.XXX.XXX:8101      ---                          ---
tcp XXX.XX.XXX.XX:3389    XXX.XX.XXX.XXX:3389      ---                          ---
tcp XXX.XX.XXX.XX:5985   XXX.XX.XXX.XXX:5985      ---                          ---
Appreciate if you can help me answer why the output is like this. Below is the configuration
0 Replies 0
