Can we Bring Down a Loopback Interface?
rais.ahmad
Level 4
Level 4
Is there any way to bring down a loopback interface on certain events? Can we track it down?
I want to down loopback0 should FastE0/0 goes down.
Thanks.
thisisshanky
Level 11
Level 11
Any reason why you want to do this ? I doubt if this is possible.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I can tell you certainly from personal experience that if you issue the shutdown command on a loopback interface that it goes into administratively down.
I am not sure that there is any way to do this automated by tracking. But it certainly can be done manually.
Rick
Rick
wkumari
Level 5
Level 5
You can admin down the interface -
int lo 0
shut
end
but you cannot do anything to shut the interface if another interface does down - why are you trying to d0 this? There is almost definately a better way to do what you are trying to accomplish.
Warren.
