Can we configure one cisco811 and ciscoASA5100 for redundcy?
francisecteo
                  Can the above be used to provide redundancy. However there is only one ISP side connected?
Any idea will be much appreciated. Of course we can set up both with exact same rules and use a Manual power on/off if
not possible.
Francis
John Peek
Can you provide a diagram of your plan of how you will hook everything up?
Richard Burts
Francis
With one router, one firewall, and one ISP it is hard to see how to provide much redundancy.
Rick
Rick
